Smoking Jimmy
Old Jul 13, 2011 | 07:53 PM
antman94's Avatar
antman94 is on a distinguished road
I took a weeeeeeee bit closer look at the area and saw that the transfer case vent tube was wet. Instantly thought it was the transfer case input seal and I pulled the fill plug on the transfer case and a good amount of fluid came out. I help the excess out and topped off the transmission just to make sure im not crazy but im pretty positive I found the problem
Old Jul 14, 2011 | 11:54 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
Yep! Mine too. Blown seal between the trans and transfer case. I relocated the vent line so it doesnt drip on the exhaust pipe. I just check the trans fluid more often.
Old Jul 16, 2011 | 09:46 PM
R134A's Avatar
R134A is on a distinguished road
Have you checked and made sure your coolant hoses were not leaking (They run over top of your exhaust manifolds) if you are running the right coolant the color is a orangeade reddish color and if it hits a hot manifold it creates a smell and smoke.
Old Jul 17, 2011 | 03:48 PM
antman94's Avatar
Yea we just replaced the coolant hoses when we flushed out the dexcool and switched to the green stuff
Old Jul 23, 2011 | 10:25 AM
antman94's Avatar
OK, Ive been driving around for about a week and a half and I went and pulled the fill plug on my transfer case this morning just to drain excess but nothing came out when I pulled the plug. So, now my question is, Is it possible that someone could have severely overfilled the transfer case and when everything heated up the fluid expanded and made its way up the vent tube?
Im just trying to get this figured out soon because I have to start driving alot in September when school starts again.
Old Jul 25, 2011 | 08:57 AM
antman94's Avatar
Bump. Still scared to drive it
Old Jul 25, 2011 | 09:32 PM
There is no way to overfill the transfer case. You do have a front seal leak, it just takes a while. It is very likely that the overfull transfer case caused the fluid to be pushed out the vent and caused the smoke.
Old Jul 26, 2011 | 10:00 AM
antman94's Avatar
Awesome, thanks for the response. Input seal here I come haha
Old Jul 27, 2011 | 08:59 AM
antman94's Avatar
I have two more questions. Is there a gasket in between the transfer case and the adapter? Also how long does this repair generally take and how difficult is it? thanks
Old Jul 27, 2011 | 10:00 AM
I have never used one, just RTV. As far as how long it takes, it's your first time, maybe the better part of a day all said and done. Depends on how experienced you are. When I dropped my uncle's NV233C, I had it done in under 3 hours from start to finish, but that was with air tools and everything cooperating.
