soft brake pedal
Old Apr 18, 2006 | 11:58 PM
lowe42's Avatar
lowe42 is an unknown quantity at this point
Default soft brake pedal
just got the front brake pads replaced on my 1996 blazer, 4by4 with abs(4.3l v6)
also replaced steering pitman arm,front ball joints,front brake hoses,master cyclinder,had the front rotors turned too,i replaced the rear axle and had the abs repaired(front harness broke)
now the problem is with the brake pedal
it is very soft,the abs dont quite kick in when they are supposed to,definetly do not feel like new brakes, you can put the pedal right to the floor, but it had better stopping power with the older worn out pads
i took it in and had gm bleed the brakes themselves but the problem came back a few days later
any ideas?
any help would be appreciated
thanks in advance
Old Apr 19, 2006 | 12:01 AM
Default RE: soft brake pedal
Something is definitely not right. It is possible that you got a defective master cylinder. Was all of this work done at the GM dealership? Make them find the problem. I wouldn't accept it. Take it back to them and since just about ALL of the system was replaced that I would think would cause this problem, it probably is a problem with the components that were installed.
Old Apr 19, 2006 | 12:50 AM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
Definitely sounds like a leak somewhere in the system or a defective brake master cylinder. Was it stopping good right after the dealership bled the brakes? There could be something that isnt completely tight and is letting air into the system slowly. Is there brake fluid dripping from anywhere?
Old Dec 23, 2008 | 09:11 AM
TAZ454's Avatar
TAZ454 is an unknown quantity at this point
Ive got the same problem, but the pedal seems to improve a little when I dont drive in the overdrive mode
Old Dec 23, 2008 | 11:39 AM
lowe42's Avatar
Sorry Taz, the original post is so old I cant even remember what I did to fix that problem. Maybe Swartllk can delete this thread and start a new one for you if you are having this problem
Old Dec 23, 2008 | 12:34 PM
Yes, please do create a new thread on this, maybe linking to this thread. Please completely describe your problem.
project85
Feb 1, 2015 08:32 PM
mrspeedy69
Oct 20, 2012 01:14 PM
bdtau44
Jul 14, 2011 11:15 PM
TAZ454
Dec 24, 2008 06:20 AM
