Some minor problems
Old Aug 12, 2021 | 11:00 AM
AceWolff's Avatar
AceWolff is on a distinguished road
Default Some minor problems
Got a 2000 blazer 4x4 ls. like 230k on it
so the issue is, it coasts at 40 in drive but idles normal in park and in neutral, doesn't take off in reverse either. Also shifts really hard from 1st to second. I read a post somewhere that had a problem similar to this and he traced it back to his fuel pump because his fuel gauge was acting up also. I find it hard to believe that the fuel pump is causing this, but my gauge is also messed up. Jumps all over.
Old Aug 12, 2021 | 11:24 AM
GeorgeLG's Avatar
So in drive it wont go below 40mph when you take your foot off of the gas?
What happens when you first put it in drive with your foot on the brake at a standstill?
The reverse gear does not engage or it does but the trans slips when you apply gas?
George
Old Aug 12, 2021 | 01:00 PM
GeorgeLG's Avatar
I forgot to ask if you have any codes and have you checked your ATF level?
Not going into reverse is almost certainly an internal trans failure and not easily addressed by the DIY mechanic. The other problems can also be trans related but can also be sensor related like the TPS, VSS, ECT, etc. I'll wait for your answers but if you want to start checking things like sensors I can help you but you will need a scanner with live data capability.
George
Old Aug 13, 2021 | 03:50 PM
AceWolff's Avatar
No it goes into reverse, it doesn't take off like in drive though. Sorry could have been more clear.
Trans fluid is good.
When I put it in drive it jumps to 2k rpm, sometimes squeeks the rear tires and then levels out at 1500 and stays there.
Cel is on for 3rd O2 sensor.
Old Aug 13, 2021 | 03:52 PM
AceWolff's Avatar
I have a scanner that reads some live data. I noticed my manifold pressure stays at about 9psi. My tps sensor always goes back to zero.
Old Aug 13, 2021 | 04:13 PM
GeorgeLG's Avatar
There are a few possibilities here.
Go in order until we find something squirely:
What is your TPS live data value at idle out of gear and then right as the idle jumps going into gear? - Is your throttle position moving or reporting to be moving?
What is your IAC value, same two conditions? - is your IAC causing this from the PCM or a malfunction.
What are your fuel trims, all 4 numbers, same two conditions? - is this a vacuum leak
What are your MAF sensor values, same two conditions?
ECT value?
MAP value?
So the transmission goes into reverse but the truck wont move or it moves but slips (rpm goes up)?
George
Old Aug 13, 2021 | 08:01 PM
AceWolff's Avatar
Reverse is normal. When I put the truck in drive it starts to take off right away like I'm on the throttle. But reverse acts normal. I'll get all the values next time I go for a ride
Old Aug 13, 2021 | 08:06 PM
GeorgeLG's Avatar
So it only revs up on its own going into forward gear at idle but the idle rpm stays normal going into reverse?
George
Old Aug 16, 2021 | 03:47 PM
AceWolff's Avatar
Yes.
Also, I've found that a mouse or something ate through the wires for the MAF and whatever that sensor is next to the MAF. I fixed those and now it runs amazing. I'm surprised I didn't get a fault code for it though. Also found a few vacume lines that were disconnected.
Old Aug 16, 2021 | 03:48 PM
AceWolff's Avatar
Now the problem is the suppension. Every part of it. Lol
