Somebody please explain it to me
Old Nov 12, 2011 | 03:09 PM
lloyddavid's Avatar
lloyddavid is an unknown quantity at this point
Default Somebody please explain it to me
Had a good fuel pump though cheap and truck '95 Jimmy, was running; then service light came on and two weeks later the truck acted like it ran out of gas; fuel pump comes on initially and will run when jumped but only puts out 30#; how can a fuel pump work fine then not put out enough pressure to start the truck? I thought a fuel pump worked or it didn't. Will someone tell me how it loses ability to put out pressure but still run? Thanks
Old Nov 14, 2011 | 10:44 AM
billbobagns's Avatar
billbobagns is on a distinguished road
There are some number of segments on the commutator on the motor and two brushes which supply switched DC to those segments. To make full pressure, all commutator segments must contact the brushes at the right time while the motor is spinning. If one of the segments ceases to contact the brush, motor power output will suffer.
Old Nov 14, 2011 | 10:48 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
alot of people have this problem when they put in a cheap pump, it lasts for a couple weeks or less then boom its toast. if you replace it with an AC Delco pump you wont have this problem.
Old Nov 14, 2011 | 11:08 AM
ChevyBlazerChick's Avatar
Also check your fuel filter. When I replaced my pump I also replaced my filter just in case. Sometimes its actually the Filter that is clogged and not a faulty fuel pump. Sometimes though, not always lol.
Old Nov 14, 2011 | 03:39 PM
lloyddavid's Avatar
Thank you for the explanation. Checked the filter and I have flow through just really low pressure; already out of the tank and I went to the Chevy dealer down the street and apparently GM does not stock the pump and assembly. So, off to search the internet. Thank you again, makes me feel better to have a little understanding.
Old Nov 14, 2011 | 05:13 PM
lloyddavid's Avatar
Okay, looks like the delphi pump is one of two
DPFE0114 $51.90 or W0133-1611657 $85.95
and the sending unit is delphi DPFL 0255 $222.50
both in stock at drivewire.com Input is appreciated as I want to do this right one time.
bowshooter1
The Chop Shop
16
Aug 20, 2012 08:33 PM
Blazer51
Jan 28, 2012 05:38 PM
CustomBlazer0047
Jun 27, 2010 06:19 PM
mortalum620
Nitrous, Super Chargers, & Turbos
14
Feb 11, 2007 03:27 AM
