Somebody please help me
I am haveing trouble with my vehicle and i dont know why.
the components i have installed are as follows:
jensen fold out dvd head unit
4 gauge rockford fosgate amp kit
2 farad power akustick Cap.
1800 watt kenwood amp
2/12" kenwood 600watt subwoofers
fold down dvd screen
1 optima yellow top battery under the hood
HERE IS THE PROBLEM:
After driving around buming my system pretty hard for a while my subwoofers will just cut off music will still play but no bass.
PROBLEM#2
When i park my truck and wait a little bit and try to start it again it just makes a single CLICK noise then all the light in dash headlights shut off at the same time as the click. then after waiting a few seconds the lights come back on and the truck starts.
CAN SOMEBODY PLEASE HELP ME OUT WITH THESE PROBLEMS I HAVE A LONG ROAD TRIP COMING UP AND I NEED THIS TRUCK TO BE AT LEAST AT 80% FOR THIS TRIP PLEASE.
PROBLEM#2
the amp is overheating and going into protect mode because the speakers are drawing to much power usuall due not being wired for the correct ohms that the amp need
or your turning it way to loud and it cant handle it
if niether is the case, check the ground if not get a new amp
for the people who are trying to help thanks alot guys im going to take it to my sponcers shop and have them test it. keep sending help its always welcome.
CUSTOM TRUCK DICIPLES Baltimore Concrete Assasins
Last edited by TripleBlackBlazer; Jun 27, 2010 at 07:01 AM. Reason: Cleaning up off topic
If the subs cutting off its either because its over heating and your going to have to add a cooling device, ie a fan. Or because either your ground or remote wire is not getting a good connection. Ive seen it where the remote wire if put into the wronge connection on the back of your head unit will let the amp play for a little then cut it off. As for the lights in your dash, problems in the electrical circuit cause all kinds of weird things to happen. I would take it to let a professional look at it. Good luck man.
As to the "Click" and all your lights going off make sure your battery cables are in good condition and tight. Not loose or corroded. Since you ran new leads to power the amp chances are your connections at the battery are poor. Good luck! Steve (cooljeep)
lloyddavid
Nov 14, 2011 05:13 PM
