spark plug #3
Old Feb 22, 2011 | 07:31 PM
  #31
stlunatics2oo3's Avatar
stlunatics2oo3 is on a distinguished road
yeah I got the swivel spark plug socket from Autozone for 6.99 and i did that plug today it was perfect length and worked perfect.
Old Aug 22, 2012 | 12:34 PM
  #32
JRP22's Avatar
JRP22 is on a distinguished road
Originally Posted by BLAZERMAN911
autozone and im telling u its the perfect length. i even took a socket with me and compared and it is smaller with the swivel already attached. i swear to you that this is perfect for the #3 plug on blazers and it only cost $5.99
hey im thinking about going to get this socket tonight to get my plugs done this week. is it made by duralast? the link that Tony put up is the one, right? for 6.99? and its a 3/8 drive, 5/8 spark plug socket. do you find it where all the spark plug sockets are at autozone im guessing?
Old Aug 22, 2012 | 12:45 PM
  #33
Tony H's Avatar
Tony H is an unknown quantity at this point
I never got confirmation that the Link I put up is teh same exact as the one Blazerman911 is happy with. I have yet to buy it. His part number and the part number I have are different, that is why I went back and questioned it.
Old Aug 26, 2012 | 11:07 AM
  #34
JRP22's Avatar
Hey i actually bought the one on your link! its dead on! had that plug out in 3 minutes. its like that socket is made for this truck! if you do plugs i recommend it strongly. i used it for all of them. worked great i had all the plugs changed in less than a half an hour
Old Aug 26, 2012 | 10:33 PM
  #35
Presti7's Avatar
Presti7 is an unknown quantity at this point
Another option is to find an old short 3/8ths extension. Walk over to a bench grinder and grind the ends at a 45 degree angle. So you can stick it in the socket on the spark plug and have your extension at an angle to break the plug loose.
Use your fingers to loosen the sparkplug socket. Installation in reverse...only using your grinded extension to break it loose, or tighten.
Old Aug 27, 2012 | 07:24 AM
  #36
Tony H's Avatar
Thanks!
Old Dec 28, 2012 | 07:53 AM
  #37
jtmcculloch's Avatar
jtmcculloch is on a distinguished road
Thumbs up
I jack the frame up on the drivers side and set it on a jack stand till the drivers side tire is just off the ground. Then i jack the engine up just a little and it is a straight shot thru the drivers side wheel well to change the #3 Sparl Plug. No need to unbolt the motor mount - there is plenty of "streach" in the rubber. No special sockets required.
Old Jan 1, 2013 | 01:39 PM
  #38
amp042's Avatar
amp042 is on a distinguished road
Took me a while to get at it but i did it. But at autozone the guy said to gap it to .045, and on some of these forums people say to gap to .060. Which is it I have a 1995 blazer LS 4dr 4x4.
Old Jan 1, 2013 | 01:56 PM
  #39
1995 4.3L takes AC Delco CR43TS with a gap of .045"
Old Jan 1, 2013 | 02:34 PM
  #40
amp042's Avatar
Aha thanks! I gapped them correctly !
