Spark Plug Change
Old Aug 14, 2011 | 04:13 AM
pwmcdaniel's Avatar
pwmcdaniel is on a distinguished road
Default Spark Plug Change
i have a 02 ls what is the best way to get to the sparkplugs to change them and what is a good plug for gas&power are e3 plug's worth the money?
Old Aug 15, 2011 | 06:01 AM
98blazin's Avatar
98blazin is on a distinguished road
everyone says to use ac delco products for the ignition system and to change them, remove front tires and go by the wheel well.
Old Aug 15, 2011 | 09:21 AM
killallblue's Avatar
killallblue is on a distinguished road
i have my ngks i like them more then my delcos
Old Aug 15, 2011 | 10:11 AM
pettyfog's Avatar
The only thing new about E3 is the way they exploit the same gimmicks that have been used since WWII and before.
Just reading this
E3 Advanced DiamondFire Technology | Top Performance Spark Plugs
makes me go 'Huh!' And many claims there are technically contradictory. They start with absolute truisms but dont explain how open front is promoted by actually shrouding the spark area. Of course they use separate thought processes and dont think you will put them together.
Funny I just saw some extravagant claim of HP and milage improvements a couple months ago. That improvement would have either driven the engine computer nuts or destroyed the combustion chambers if true. Something about 8% hp and 15% mpg. That would have meant your car was barely running when you put them in.
The ONLY improvements in basic spark plug design in the last 50 years have been alloy electrodes.
Otherwise those old car company designers pretty much hit it dead on.
And, even then, Bosch who more or less designed them cant get the heat ranges right for our cars! Bosch sux {no load misfires on Fords.. probably same with GM} unless you order one or two ranges hotter. Do you want to bother?
If you're buying plugs, use your head gather a consensus of everyone not just a few..
AC Delco or Autolite for GM
Motorcraft, Autolite or AC Delco for Ford
See a pattern?
When the car companies put them in the production line, then you'll know you're not being taken.
Old Aug 15, 2011 | 11:30 AM
chris015's Avatar
E3's are a joke.
Run Ngk or ac delco
NO Bosch!
Old Aug 15, 2011 | 11:53 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
stick with the tried and true. If they werent any good, they wouldnt be tried and true!
Old Aug 15, 2011 | 04:31 PM
step66's Avatar
Spark plug choice matters little,but all small-blocks like original fire! Stay away from the "Gimmick" plugs-I have had NO problem from either Bosch,Autolite or AC! Just avoid the multi-electrode plugs
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
AutomagicLS1
Oct 5, 2008 06:50 PM
boulonman
Mar 5, 2007 05:10 AM
cuzfu
Nov 6, 2005 02:32 PM
