Spark plug non-fouler O2 sensor trick: Will it be foiled by a hollow cat??
Old Sep 17, 2014 | 12:19 PM
burned's Avatar
burned is on a distinguished road
Originally Posted by TonyZR2
Um.............help.
I drove it until almost test ready (only OH and EV left). And NO returning P0420. Then after all that driving, in one trip to Aldergrove, I go home to bed for work, then in one trip tonight .........it throws TWO codes, P0335 (Crankshaft Position Sensor A Circuit). Then.......P0137 (O2 Circuit Low Voltage [Bank 1, Sensor 2]). This was in hard driving in which I floored it several times.
Apparently........these two codes will make me fail Aircare?
That code indicates power is being lost to the sensor. Check for battery voltage on the pink wire to the crank sensor. It could be a poor or loose connection at or in the fuse panel, in the pink wire itself, or the connection at the sensor, or a faulty sensor. The crank sensor may also be hitting the reluctor ring. Pull out the sensor and have a look at it to see if there are any scuff marks. If it has been hitting it will need to be replaced and shimmed.
Old Sep 17, 2014 | 01:17 PM
TonyZR2's Avatar
TonyZR2 is an unknown quantity at this point
Thanks.Oh, when that happened with those two codes thrown under hard accel. up hill on the hwy, something strange happened..............while the pedal was matted, the tach needle spazzed back and forth really fast between 4000 and 6000 revs, maybe 5 times....all within a second or two. Yes, the whole truck also surged/shuttered during that short time. So that I don't understand.
Old Sep 19, 2014 | 12:44 AM
TonyZR2's Avatar
Passed Aircare!!
Old Nov 16, 2023 | 11:24 AM
GeorgeLG's Avatar
You are having spark plug wire problems, this is a thread about O2 sensors and cats that is almost ten years old. Start a new thread and ask your question.
George
tulsablazer97
May 19, 2014 07:14 PM
1Hoss
Oct 27, 2012 11:16 PM
taba5
Feb 25, 2010 12:07 PM
2doorblazer
Oct 17, 2009 12:05 AM
Shaggz
Dec 11, 2007 05:49 PM
