Speedometer inaccuracy
Old Jul 7, 2013 | 01:26 PM
LannyL81's Avatar
Default Speedometer inaccuracy
Is there someway to calibrate the speedometer or at least check it? I have been checking the speedometer against one of those signpost radar units. My other car is within 1mph, but the Blazer is way off....the speedo is showing faster than what the radar speed display shows.
Now I put larger diameter tires on, but I though this would cause the speedo to indicate a slower speed than actual....but it appears to be the opposite.
I have not check the odometer against highway mile markers yet.
So again, any way to check speedometer calibration?
Thanks.
Old Jul 7, 2013 | 03:12 PM
rexazz2's Avatar
I checked mine against my GPS when I went to 30's
was pretty close
BTW I think bigger tire diameter will make you go faster than the speedometer reads
Old Jul 7, 2013 | 04:36 PM
Easiest and most accurate way to check the speedometer and odometer is like Rex mentioned, with a GPS. And yes, larger tires will indicate slower than actual because they rotate at a slower speed, (less PPM, pulses per mile, as measured at the VSS). The PCM can be recalibrated using a Tech2 scan tool.
Old Jul 7, 2013 | 05:04 PM
abig84's Avatar
the tinfoil hate wearers will say its so your warranty goes up faster on your truck. but ive noticed that in every car/truck ive owned and anyones i drive past those radar things im always going like 2mph faster on my speedo then the radar is stating
Old Jul 7, 2013 | 06:46 PM
rriddle3's Avatar
Every manufacturer has a +/- margin of error in their speedo programming. It's better if yours read high rather than low.
Old Jul 7, 2013 | 06:54 PM
247monster's Avatar
if you have a smart phone i use an app called Ulysse Speedometer
one of my fav apps just cause its actually useful lol
sandman1412
Jun 27, 2010 02:27 PM
AlaskanK5
Jan 10, 2010 10:32 PM
bellert
Aug 31, 2006 03:19 PM
mgrnwd
Jul 14, 2006 01:24 PM
swartzy
Tires and Wheels
15
Mar 22, 2006 11:59 AM
