Speedometer reading fast
Old Aug 10, 2021 | 05:21 PM
Mdz320's Avatar
Mdz320 is on a distinguished road
Default Speedometer reading fast
I have a 2000 blazer, 2dr, 4x4. My speedometer (50)is reading about 4 or 5 mph faster than a GPS (45-46)app shows.
Tires are standard for this truck, 235/75R15.
Help please.
Old Aug 10, 2021 | 10:42 PM
A dealer might be able to reprogram the computer (ECU or BCM) so that it is calibrated correctly. I was looking at an OBD reader that I think, if I read the specs correctly, could do this too. (https://www.videntstore.com/wholesal...scan-tool.html)
Old Aug 11, 2021 | 08:21 AM
I think it's fairly common for speedometers to read a little bit fast. Maybe not that much, though. Personally, I would probably "correct" the problem by replacing the tires (when they're worn) with the next size bigger. You might also find some that are the same size but actually measure larger. Check out the specs for revolutions per mile. Most tire manufacturers provide this.
Old Aug 11, 2021 | 08:36 AM
Mdz320's Avatar
Last I remember, recent history, it had been accurate. Theres been no tire change or issues.
Old Aug 11, 2021 | 09:29 AM
That's odd, for sure. If you have a scanner, maybe check the speed sensor output to see if it matches the gauge? Could be that the speedometer itself is not reading accurately. Just a WAG, though.
Old May 22, 2022 | 10:45 AM
Mdz320's Avatar
I replaced my tires. I'll get back to this post when I can see if it makes a difference. Currently getting my fuel pump replaced.
iceblue068
Mar 28, 2019 04:41 PM
LannyL81
Jul 7, 2013 06:54 PM
Chris Mendoza
Jul 24, 2011 09:33 PM
moldeck
Tires and Wheels
Mar 2, 2010 07:03 AM
c5ce
Jan 9, 2009 10:44 PM
