spiitin n sputterin
Old Jun 16, 2011 | 11:13 AM
Meleke's Avatar
Meleke is on a distinguished road
Default spiitin n sputterin
i too had that same problem i have a 95 2dr. the spider injector ($300) was bad n broken replaced that it ran fine till now it's been 3 mths. now it's done it again n i dono whats going on. we replaced the fuel pump, ignition control sencer,plugs ,wires,and cap ,rotor button still wont start now. lookin for ideas myself n none of the machines that gives codes work on it. anyone have any idea's?? would love the help. i'm outta ideas.
Old Jun 16, 2011 | 11:38 AM
*Moved to a new thread* - so we don't take the other thread off topic given that these are two different engine types.
To read the codes on a '95 model year vehicle, you first need to determine what kind of engine management computer there is. There were 3 different types:
  • Full OBD1 with the standard square OBD1 plug under the dash and the ECU was located behind the glove box. Codes can be read using the standard "paper clip method" (check troublecodes.net)
  • OBD1.5 which was a mix of OBD1 & OBD2; the computer is still located behind the glove box, but the diagnostic port is the OBD2 type (isosceles trapezoid if you are a geometrical kind of person). This type requires a scan tool that specifically calls out that it will work with '95 model year GM products.
  • Full OBD2 which will have the PCM located under the hood on top of the coolant overflow bottle on the passenger inner fender.
I'm betting that you have the OBD1.5 system. There was another member that had success in getting the OBD1 type trouble codes to display by placing a jumper wire across two of the pins on the OBD2 port. But that would still leave the OBD2 codes that may be present.
But I really would start with a fuel pressure & leak down test. The fuel pressure needs to remain above 55psi at all times and shouldn't drop below 50psi during a 10minute wait from the time that the pump shuts off.
Old Jul 4, 2011 | 05:04 PM
Meleke's Avatar
the obdem check plug is unhooked somewhere n they can't find it there for it's of no use to me. replaced the fuel pump ignition control moduel worked for about 1 mth. the cap n rotor was replaced for the 2nd time it was burnt up but this time is fine. outta ideas
jmonshau
17
Mar 8, 2013 03:29 PM
claughlin89
Jul 9, 2009 08:44 PM
