spindle nut removal?
Old Dec 1, 2009 | 01:49 PM
WolfPack's Avatar
if you can get to the nut with the wheel on
I had a few problems getting mine off. First I couldnt find a heavy-enough duty extension. The deep well socket was not tall enough to get out past the lip of the my rim (took the center cap off, put rim back on), so I tried a short extension...twisted the extension in no time..then I used an impact extension, and ended up breaking a cheap Harbor Freight socket wrench...ended up having to buy a bigger breaker bar, but the extension still torqued and twisted and is not usable anymore.
I had to end up taking the rim off. I used a thick screw driver and jammed it down in the rotor slots, and turned the rotor so that the screw driver's barrel was against the caliper bracket. Still took a few feet of pipe and lots of force, but it came loose. Air tools are your friend after you break it loose!
Old Dec 1, 2009 | 02:35 PM
By far the easiest method is with an air impact!
Old Dec 1, 2009 | 04:44 PM
echild's Avatar
echild is on a distinguished road
no luck yet! i broke two breaker bars and a electric impact today..even with a few feet of pipe it didnt budge.....next up is a air impact! if that dont work its going on a tow truck and right to the shop...lol
Old Dec 1, 2009 | 04:54 PM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
X2!!!
Umm, just checking here, but lefty loosy, righty tighty?
Old Dec 1, 2009 | 05:12 PM
echild's Avatar
yeah i was turning it lefty..lol...
Old Dec 2, 2009 | 01:37 PM
jstutzman's Avatar
jstutzman is on a distinguished road
36mm deep at autozone loaner tool, i have a good 1/2 impact, I set the air pressure at 90 psi and it buzzed it right off. I tried with conventional tools for about 1 min and said "f" that. Good luck
Old Dec 2, 2009 | 04:30 PM
echild's Avatar
yeah i need a good air impact...
Old Dec 3, 2009 | 11:12 PM
echild's Avatar
ok after 1 more breaker bar down and no luck on the air impact.i am lost,what else can be done?
Old Dec 4, 2009 | 02:55 AM
W2JGA's Avatar
Other than finding a good 1/2" to 1" impact, putting a torch on it is the only other thing I can think of.
Old Dec 4, 2009 | 07:12 AM
Change where you are buying your breaker bars... I have only broken one breaker bar in all of them that I have (mis-) used and that one was 20+ years old already and a little loose at the head. I have a heavy knuckle Craftsman 1/2" long bar that has really held up quite well.
Be careful with the heat if you do it. Heat it some then cool it down with penetrating oil and then heat it again and try to loosen it. If it doesn't come, repeat.
