A squirrel ate my wiring!
Old Jun 22, 2012 | 10:19 AM
KCEE's Avatar
KCEE is on a distinguished road
Default A squirrel ate my wiring!
Go ahead and laugh, it's true. I am new to this forum and could use some help.
My 1999 S-10 blazer 2wd 4.3L had the Central Sequential Fuel Injection electrical connecter chewed away. I bought an old partial wire harness from a junk yard. I have figured out all but where the pink wires go to and from. Can anybody help?
Old Jun 22, 2012 | 09:44 PM
AJBert's Avatar
I've had a couple of vehicles that had rodents eat on the wire.
Can't help you on where the wire goes, but the best jambalya I've ever had was squirrel and cajun sausage!
Old Jun 23, 2012 | 08:58 AM
Each of the pink wires in the injector connector go to the underhood fuse panel to the EMC 1 fuse which has battery voltage with the ignition in the START and RUN positions. They all are connected together inside the fuse panel. There are several pink wires in the engine wiring harness: ignition coil, ignition control module, crankshaft position sensor etc and all have battery voltage in START & RUN. Each of the other wires in the injector connector are supplied ground from the PCM to open each individual injector.
Old Jun 23, 2012 | 12:13 PM
KCEE's Avatar
Thanks folks. I found a schematic at the library last night. It is exactly like Captain Hook said. I should have it up and running soon.
WildDomesticTabby
Sep 10, 2014 08:05 PM
rexazz2
Nov 6, 2013 09:03 PM
ComputerNerdBD
Apr 28, 2012 09:46 AM
speedhead
Mar 16, 2012 06:54 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
