Starter spinning - fixable?
Old Oct 26, 2010 | 12:12 PM
Tortex53's Avatar
Tortex53 is on a distinguished road
Default Starter spinning - fixable?
Sometimes when I turn the ignition switch, my starter just seems to spin without engaging the flywheel. After a couple of tries, it usually engages. I did some research on the forum, and it appears to be something about the "bendix" not pushing the starter gear forward. Is this something that can be repaired or cleaned, or do I need to go buy a brand new starter for $115? Thanks.
Old Oct 26, 2010 | 08:54 PM
Sparky's Avatar
Sparky is an unknown quantity at this point
You can change just the Solenoid mounted on the starter (about $50). But you'll have to drop the starter out to change it.
Old Oct 26, 2010 | 08:57 PM
84BlazerS10's Avatar
Yeah, exactly what Sparky said.
Old Oct 26, 2010 | 09:07 PM
cbr995's Avatar
All I can say is +2.
Old Oct 27, 2010 | 12:07 AM
s14sh3r's Avatar
If it's just clicking, then starts eventually, it's usually the solenoid. If you can hear the starter spinning, but it won't engage, it's usually the starter drive AKA Bendix. They're not hard to change if you're reasonably mechanically minded. You can get them at the parts store for around 20 bucks, maybe less. I'm not sure if Autozone or the like carries them, but a real parts store will*.
*Not ragging on Autozone by any means, but there are lots of things they don't carry.
EDIT: Disregard the above. I don't know what I was thinking when I posted that. Sparky had it right. It's probably the solenoid, and yes, they're replaceable.
Old Oct 27, 2010 | 10:15 AM
Tortex53's Avatar
Thanks for the info. It's not the solenoid because it always spins; it just doesn't engage the motor. I'll see if Napa carries the Bendix.
Ok, I just reread Sparky's post and realized I missed the additional comment. If it always spins but doesn't engage the motor, would that really be the solenoid?
Last edited by swartlkk; Oct 27, 2010 at 10:39 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Oct 27, 2010 | 10:37 AM
1998MSO's Avatar
1998MSO is on a distinguished road
You're going to have to remove the starter no matter what so I would just recommend you replace the starter and solenoid all at once. Yes, it's a bit more expensive but removing/installing the starter isn't the easiest on these vehicles.
Old Oct 27, 2010 | 11:23 AM
The solenoid energizes the starter windings as well as pushes out the bendix. So yes, a solenoid issue can definitely cause the symptoms you are experiencing. You can replace only the solenoid, but I would fully inspect the starter to make sure that the nose cone bushing and the brushes are both in good condition. For the nose cone bushing, just check for play where the main shaft is fitted into the nose cone. For the brushes, you will need to pull the rear cover off of the starter motor itself (two really long screws). If the rotor where the brushes contact is black or badly scored, replace the starter.
KellenR
Oct 22, 2013 06:01 PM
ComputerNerdBD
Mar 21, 2012 07:50 PM
vinnivanhood
Apr 1, 2011 06:23 AM
zashwood
Dec 30, 2010 07:51 PM
Blazin87
Sep 4, 2006 01:40 PM
