starting problem
starting problem
I recently replaced the 02 sensors on 1999 blazer, now it won't start
I replaced spark plugs but it didn't help
any ideas on what could be the problem
Thanks
Thanks
Is it spinning over just won't crank up?
starting problem
yes it spins but just won't start
I assume that it was starting just fine before the work was done on it.? Have you gone back over everything that you replaced as well as everything in the area(s) where you were working?
Have a look through the thread linked to below:
No-Start - Engine Cranks OK - Ignition System Diagnosis
*Moving to 2nd Gen Tech* - Please read the descriptions of the forum sections and choose the section that most closely fits to the topic you are intending to post. Thanks!
check for spark n fuel. might b an unfortunate coincidence. fix one thing n something else breaks. o2 sensors shouldnt cause a no start
cgrett
11-15-2010 09:08 PM
Sprocket
03-20-2008 09:39 PM
mickey2001
03-13-2006 11:51 AM
