starting problems
Old May 20, 2011 | 10:54 AM
jimd123's Avatar
jimd123 is on a distinguished road
Default starting problems
I have a 99 blazer 4.3 Fuel pump was replaced and the truck started. Now it won't start. I have plenty of fuel pressure, spark and all the relays seem ok. Any ideas of what it could be?
Old May 24, 2011 | 11:55 AM
What is the fuel pressure in psi and does the pressure remain above 50psi for 10 minutes after the pump shuts off?
Old May 25, 2011 | 07:56 PM
jimd123's Avatar
Fuel pressure stays up. I read some other threads that mention checking the battery. The battery cranks fine and charges fine but when I tested it the tester said the battery should be replaced. It seems to have worked although I don't know why it did because I don't know what the battery would have to do with it after the truck started.
cgrett
Nov 15, 2010 09:08 PM
upblazer95
Apr 4, 2009 08:27 PM
Sprocket
Mar 20, 2008 09:39 PM
Dean S
Jan 30, 2006 02:51 AM
smplgrn
13
Jan 23, 2006 09:02 PM
