steering play
Old Dec 7, 2010 | 12:30 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Default steering play
i have a 97 blazer, and ever since i got it a year ago it has had a little play in the steering wheel. i took it in and the shop said it was the driver side tie rod and idler arm so i had it replaced and it didnt help at all. when i turn the wheel back and fourth through the play which is about 1/8th turn on each side the shaft going down towards the axle turns but not the tires. so my guess is its play in the gear box but not sure. please help, thanks
Old Dec 7, 2010 | 12:44 AM
stlwaco's Avatar
stlwaco is on a distinguished road
search for rag joint
Old Dec 7, 2010 | 08:45 AM
doesn't a worn rag joint cause the truck to wonder? because my truck doesn't wonder at all just sloppy steering. or does it cause both? thank you for the help.
Old Dec 7, 2010 | 08:48 AM
A worn rag joint may not necessarily cause a truck to wander. It will exaggerate corrections since there is slop before the steering gear box, but if the rest of the steering linkages and the gear box are tight, it shouldn't wander.
Old Dec 7, 2010 | 10:23 AM
g_mike's Avatar
g_mike is on a distinguished road
i had sloppy steering and i just changed out my sway bar links, big difference.
Old Dec 7, 2010 | 04:16 PM
to check that do you just have to get under the truck and have someone turn the wheel? or can you not see it from under? thanks for the help tho that sounds like its the problem
rasputinlv
Jan 26, 2010 05:18 PM
rasputinlv
Jan 26, 2010 06:06 AM
Kojak
Jan 23, 2008 06:28 PM
Turismo
Nov 8, 2007 12:25 PM
1996blazer
Sep 23, 2006 01:19 PM
