Still working on front differential
Hello all,
I am hoping this gains a bit of traction because I need some advice.
As mentioned in another thread, ever since buying this truck it has sounded like the front passenger wheel bearing was bad. It's very growly and mechanical sounding. Same in 2wd or 4wd. Most noticeable at speed, 15-35mph, and gets louder on hard left turns at speed.
well I replaced the wheel bearing and it fixed nothing. Now it's getting worse. I pulled apart the front end, CV axles look fine. I need to get the front diff out so I can replace a motor mount but I cant get the stupid thing out... working with a couple 18mm open end wrenches with only a few inches of room under the truck. Do I have to remove the upper control arm to make life easier?
I would be beyond pissed if i only replaced the output bearings and it ended up being a pinion bearing - but again, it is very clearly coming from the right side.
Questions being: Any advice on source of noise? & Any advice on getting mounting bolts for the diff loose? If I get it out, should I just go buy a used one from eBay (truck has 225000M on it)?
Don't think it would be a pinion bearing, since in 2wd the only thing turning in the diff is the spiders.
I can't remember if the upper arm needs to be removed, the lowers will, for sure. If all you have is open/box end wrenches it's gonna suck. You need at least a socket and several extensions. Get an impact, it will make your life so much better
Why do you ask?
In regards to the tools, I have an impact and full socket sets (swivel, deep, standard, metric, etc), the problem isnt a lack of tools, it's that it's impossible to get in there with anything other than open end wrenches and at least 1 mounting bolt goes through a rubber bushing that I'm sure is rust welded itself to the bolt shaft. Would be a complete disaster for the home gamer... if I had a torch I'd blow the nut off or cut the bushing out.
The noise gets worse on hard left turns? You've changed the passenger wheel bearing, right?
I would look at the cv before you do anything else.
Also, how certain are you it's coming from the front? Maybe it's a rear wheel bearing making the noise?
Obviously without a chassis ear I cant be 100% positive, but from the drivers seat it seems to clearly be coming from the front passenger.
But I'd at least he glad I figured it out finally.
Well, for future google searchers of similar issue I thought I'd post a conclusion... after tearing the entire front end apart and changing output bearings and putting it all back together I swapped the front tires, and I can't be certain, but to me it sounds as if the noise has moved to the passenger side... so yeah, it may only be a freaking tire.
And of course I may just be hyper aware now but there seems to be a new rattle that is driving me nuts. Double checked all the suspension bolts and it's not that... so I have no idea... sweet.
I'm done working on this thing for a bit, lol.
