strong gas fumes when running
I have a 97 blazer and when the truck is running there is a strong smell of gas coming from under the truck it don't leak any fuel but i am also getting bad gas mileage any ideas please help
ive never heard of the shrader valve do you have any info on it pics or diagrams that would def help also i was looking around the gas tank and there is a hose thati dont know where it goes or comes from look like it might come from the top of the tank where can i find a diagram of the fuel lines ?
Guest
Posts: n/a
You have a different motor then me. It should be on one of the two fuel lines that come up on the drivers side under the hood before they enter the plenum. There may or may-not be a screw on plastic cap. Looks kind of bullet shaped if there is no cap. The valve itself looks the same as the airfill on a tire. Check it with the key on. They just kind of seep. Sorry can't help on the fuel lines. Plenty here on them, mostly under fuel pump change. Use the google engine on BF main page.
ludejim
Nov 26, 2008 06:11 AM
hollisterdj
Dec 1, 2005 03:22 PM
