Stubborn oil pan
Old Apr 1, 2008 | 09:30 PM
ImRaptor's Avatar
ImRaptor is an unknown quantity at this point
Default Stubborn oil pan
Trying to get the oil pan off my 99 blazer to ge the pan and oil pump replaced. My problem is that the oil pan will just not come off.
I triple and quadrupled checked that there are no bolts left holding the pan.
I've beat the living crap out of my dead blow hammer trying to get the pan to even break free a tiny bit. Nothing, not even a tiny bit of movement.
Figured since I was planning on replacing the pan anyway, I would pry on the side of it away from the block and in the ridges of the pan. Still can't it to move.
Tossed a 5 foot pipe onto the end of the pry bar to get the pan to move. Bent the bar...
At at my wits end on getting this pan off, its such a simple thing but it driving me insane. Any suggestions on something else to try to get this pan free from the block?
Old Apr 1, 2008 | 10:07 PM
WolfPack's Avatar
Default RE: Stubborn oil pan
I'm pretty sure the pan doesn't just 'come off' on the 98+ models.
Yep...a quick search:
ORIGINAL: swartlkk
With any '98+ 4.3L, the engine must be disconnected from the transmission bellhousing to allow for proper alignment of the oil pan upon reassembly. The cast aluminum oil pan is a structural component of the engine and transmission connection and precise placement is required for this. It may be possible to pull the pan and get it aligned properly without pulling the transmission, but you may then have to remove the front timing cover. The oil pan is sandwiched between the timing cover at the front and the transmission bellhousing in the rear. If you could do this without damaging the seals, then you will either have to remove the front axle, or jack the engine if there is enough room to do so (which I doubt).
Book calls for the removal of the engine to remove the oil pan.
Hopefully you didn't break something else other than the pan!
Old Apr 2, 2008 | 05:28 AM
It is possible to remove the pan without loosening (or disconnecting) the transmission, but the transmission should be loosened to put it back on in proper alignment.
Did you pull the 4 or so bolts out of the transmission lower bell housing?
Old Apr 2, 2008 | 01:25 PM
ImRaptor's Avatar
Yep, removed all the bell housing attaching the pan.
After some more searching around, I'm not the only one to have a really hard time getting the pan off.
When I get a chance I am going to pull the timing cover off and try and break the seal from there. If I can get the seal to start to break free I'm sure it will come off.
Old Apr 2, 2008 | 05:09 PM
The problem is how tight the pan fits to the block and to the transmission bell housing. If you were to loosen the transmission from the back of the engine, I am sure that the pan would be easier to remove. But that is MUCH easier said than done.
Old Apr 3, 2008 | 07:19 PM
ImRaptor's Avatar
ORIGINAL: swartlkk
Thanks for the info. Definetly going to give it that a shot next week when I get a chance.
Bluebeastblazer57
Aug 11, 2012 11:05 PM
C5Longhorn
Mar 29, 2008 10:40 AM
Birk21883
Jan 12, 2008 12:02 PM
swartlkk
13
Dec 20, 2005 08:13 AM
