Stuck 02 sensor
Stuck 02 sensor
Im trying to change one of my 02 sensors on the y pipe.Its been already removed from the engine.Today I tried using some map onit heated the fitting cherry read and tryed to losen.The darn thing wont budge hat do I do get a hotter torch like acyteline?I need to get removed.Thanks for any help I can get.
Did you get the sensor out? I've got one to replace in the near future and I'm pretty sure its an original - 11 ontario winters of road salt(eugh), i might just send it to the garage........ So far on rusted and siezed parts 'PB Blaster' penetrating oil has come through every time for me - haven't had to touch a torch yet
i stripped mine out last time so i had to use a VERY large pipe wrench to get it out. took two hands and all my strength to get it busted loose. and when it did it took the threads with it. and they acually make a special tap that you can use to reshape the threads to get a new one in. i got mine at advance auto
I when tryed removing mine I put a pipe wrench and cheater piep on it with heating up with map gas torch.Didnt budge or phaze it.I have seen them taking out with special socket and actyline torch.My neighbor across the street has one so Im going to see if he can get it out for me.
dsevern
08-12-2011 10:39 AM
Havensk
07-25-2010 08:16 PM
