stuck caliper?
Old Oct 10, 2012 | 07:02 PM
nalgman's Avatar
nalgman is on a distinguished road
Default stuck caliper?
hello to all..
today i was changing some tires between my two blazers...
and i discovered that the blazer 4x4 2001 zr2 , are really hard to turn the disk brake..
the left side is a little more difficult. but my general question is..
the disk brakes on a 4x4 are that hard to turn with the hand??? note: with no tire.
or easy with one hand??
or maybe i have bad calipers?
thank you...
Old Oct 10, 2012 | 07:05 PM
chris015's Avatar
They shouldnt take alot of force to get it to turn. Sounds like you have a sticking caliper.
Old Oct 10, 2012 | 07:31 PM
nalgman's Avatar
just to be shure.. i take off the rear tire and try to turn the disc.. well.. consider that the rear are attached to the differential and all the stuff.. was less difficult to turn .
the front left are more difficult to turn and the right almost the same but lighter..
so, if i need to replace these calipers...
a regular caliper from a 2001 blazer non Zr2 will fit??
that's my fear!!
thank you man
Old Oct 10, 2012 | 08:32 PM
chris015's Avatar
they are all the same.
Old Oct 10, 2012 | 08:39 PM
spittybays
Guest
Posts: n/a
Are they heating up or pulling to one side when you drive? Are you sure the front diff is not engaged? They should be easy to turn and if there dragging they should be getting hot.
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
Ted
Sep 14, 2009 11:26 PM
Canadian88
Jul 20, 2006 08:41 PM
