Stumped!!!!!!
Old Sep 22, 2009 | 11:42 AM
royillt's Avatar
royillt is on a distinguished road
Default Stumped!!!!!!
ok, lets go over a history of whats going on. the truck was running and driving when it started stalling out, after a few times it wouldnt start at all just crank AND it wouldnt unlock in to nuetral. just as i was about to give up and called the tow truck, it fired right up and drove home fine. after a few times the problem was back with no start. the truck has been to the shop and the cpu and altenator have been replaced and programmed. the truck fired up and drove home w/ no problems. after turning it off it wouldnt restart... just crank. it seems to wants to fire up every few months or so just fine but will just die after awhile and go back to endless cranking. something is interfering w/ the spark but i cant figure it out and cant afford to keep throwing money at it. it also IS NOT throwing any codes. if anyone can lead me in the right direction it would be greatly apprieciated
Old Sep 22, 2009 | 11:59 AM
rriddle3's Avatar
Stumped!!!!!!! Yeah, me too. What are you driving?
Old Sep 22, 2009 | 04:03 PM
old skool luvr's Avatar
Originally Posted by royillt
ok, lets go over a history of whats going on. the truck...........
well, we know he's driving a truck, not a car. that should narrow it down some (i wonder if it's a GM product)
Old Sep 22, 2009 | 07:39 PM
royillt's Avatar
ha,ha guys, sorry its been a while. i have a 97 blazer ls 4x4 w/ 4.3 liter engine w/ a/c.
Old Sep 23, 2009 | 03:41 AM
awe341's Avatar
awe341 is on a distinguished road
Well, if it's not getting spark then you need to run through the basics of the ignition system and start checking each part. It sounds like a possible ignition control module problem but it could be a number of other things as well. Including a bad ignition switch.
I'd start by testing those two components first.
Old Sep 23, 2009 | 07:52 AM
jamel's Avatar
jamel is on a distinguished road
I'm having the same problem with my 2000 chevy blazer now the truck will not start at all! I need help bad! when You find out what's going on please post results!
Old Sep 23, 2009 | 07:45 PM
rwright99's Avatar
rwright99 is on a distinguished road
Default also stumped blazer wont start
i have a 99 s10 blazer and it has spark and fuel and will crank over but not start the fuel pump is good and works has new plugs and wires what next?
Old Sep 23, 2009 | 09:17 PM
rriddle3's Avatar
If you have an issue with your truck, please start a separate thread.
Old Sep 23, 2009 | 11:12 PM
have you checked the ignition system completely? i'm talking about the ignition module, coil, TPS.........everything.
Old Sep 28, 2009 | 05:58 PM
royillt's Avatar
UPDATE! i would like to say thanks to thoughs for pointing me in the right direction,,
it was the ignition module... got one for $10 bucks and ha been running ever since
BIG UP TO blazerforum.com
