Sudden Severe coolant leak
Old Mar 24, 2015 | 08:50 PM
antman94's Avatar
antman94 is on a distinguished road
Default Sudden Severe coolant leak
I took a drive to the diner last night about 2 miles from my house, no problem at all, parked in the lot with nothing new catching my eye. Upon leaving, i was driving down the road and as I was almost home I realized my truck was smoking a little bit. I drove the last couple hundred feet and my truck was smoking from under the hood (burning coolant off) like crazy.
I pulled into the garage today and refilled the radiator and reservoir and fired her up. Even before starting I heard the coolant running out and on to the ground. I fired it up and it looked like the coolant was coming from the drivers side from right under the air conditioning compressor, then running down between the valve cover and intake manifold and pouring out onto the ground mainly towards the back of the motor. While running for a minute it made about a 2 1/2 - 3 foot puddle. I know for fact its not the upper radiator hose. Its a really big leak but I don't see anything definite leaking but want to know if theres anything common I should check before I start assuming its the L.I.M. gasket.
thank you.
Old Mar 24, 2015 | 09:01 PM
Remove the AC compressor and move it off to the side. You should be able to see if the lower intake manifold gasket is leaking. That's a very common place for them to leak. It's not a difficult job, but there are some things that need "special attention", and a list of do's & don'ts.
Old Mar 26, 2015 | 10:31 AM
Tajohns34's Avatar
Definitely sounds like an intake gasket.
Old Mar 27, 2015 | 01:50 AM
Spree's Avatar
Spree is on a distinguished road
Just do the LIM gasket. Cheap and easy fix!
Old Mar 27, 2015 | 08:26 AM
keith cloutier's Avatar
keith cloutier is on a distinguished road
make sure its not upper radiator hose, mine rubbed on smog pipe tubing and ran down valve cover,it made it look like lim gasket was leaking. lift hose and check underneath.
dharvey4651
Apr 3, 2015 05:30 PM
Beera
17
Sep 3, 2012 03:15 PM
jmac219
Oct 16, 2010 08:33 AM
92S20blazer
Feb 18, 2010 09:42 AM
kerander
Jun 5, 2009 01:50 PM
