Suddenly won't start
Old Feb 27, 2010 | 12:34 PM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
Default Suddenly won't start
2001 4-door LT V6 auto 4WD
Recent history of unsolved EVAP and AIR codes. (All EVAP equipment seems to look good. The EVAP canister is also exposed by a hole in my bumper.) Was waiting on tests to finish running; 300+ miles later, 2 out of 4 tests still had not run.
Started and moved the truck a few feet yesterday. Started up fine. Started it up twice no problem actually. Didn't really drive it anywhere.
Today, just as I need to take a check to the bank, the thing won't start. Service engine soon light has popped back on for the first time since new battery a couple weeks ago. No way to read codes right now. Starter fires, but for the most part, nothing out of the engine. Occasionally it starts to engage, but doesn't really turn over. After those occasions, if I turn the key off, it sometimes jumps and bucks a bit after.
A couple times in the past it didn't quite want to start immediately, but after a few times of firing the starter, the engine would kick in.
Any insight or guidance appreciated, thanks!
Old Feb 27, 2010 | 12:43 PM
So the engine is actually turning over, just not firing...? Is that correct?
Old Feb 27, 2010 | 12:46 PM
I believe so. As long as I have regular starter noise, that equates to turning over, right? I've never been 100% clear on that term.
But occasionally it seems like it starts to/wants to fire ... and on those occasions, if I pull the key, it still kicks a bit after.
Old Feb 27, 2010 | 03:51 PM
Turning over means that the crankshaft is actually spinning. If your belts are moving, then the motor is turning over.
If the starter were to not engage the flex plate, you could have starter noise, but the engine would not be turning over. However, the noise is quite different.
Old Feb 27, 2010 | 06:56 PM
jimhens82's Avatar
jimhens82 is on a distinguished road
open the hood and look while someone cranks the engine, to see if your cranking like kyle said, if its cranking and not starting theres an issue, but if your starter isnt grabbing the flexplate then your noises will be way different. does is sound like a normal engine cranking over or a grinding or a spinning noise? or just a click
clear this up and we will all help you out.
Old Feb 28, 2010 | 01:14 PM
Seems to be turning over, yes. I just marked a belt and hit the ignition myself, but yeah, mark had moved.
Old Feb 28, 2010 | 04:04 PM
Yep, buddy had a chance to stop over finally. Definitely turning over.
Old Feb 28, 2010 | 09:03 PM
jimhens82's Avatar
is your battery ok, if so, id check for fuel pressure. sounds like it could be the pump if i am reading your post right. turn the ignition on and listen for the fuel pump to prime. should hear a buzz from the tank when you turn the key on. if no buzz, ur pumps probably out. pretty common on blazers.
Old Mar 1, 2010 | 05:17 AM
as mentioned, battery is near-new. that said, it died oddly quickly about a month ago ... I don't think I have many electrical tools here, not sure I can check the battery further at this time.
also, should have mentioned, the pump primes fine. it maaaaaaybe kind of seems like the almost-firing I get out of the engine occasionally is more likely to occur if I let it prime longer, or prime until the priming noise stops after a few moments ...
could it be a fuel filter issue? where is the filter on these?
Old Mar 1, 2010 | 09:03 PM
jjnemoiii's Avatar
jjnemoiii is on a distinguished road
The fuel filter is underneath your vehicle, mounted to the frame rail on the driver side, between the gas tank and the engine compartment.
