Sun visors don't line up with ceiling hooks
Old Nov 16, 2023 | 03:03 AM
Schewe's Avatar
Schewe is on a distinguished road
Default Sun visors don't line up with ceiling hooks
Hey all.
Here's an anomaly that has existed ever since I bought my 2003 Chevy Blazer LS: my sun visors are too... long?
As you can see in the photos the little bar doesn't line up with the ceiling hooks, leaving the visors to shake and vibrate when driving. I've always been baffled as to how this is the case-- my guess would be that these are not the original visors but I highly doubt the previous owner would've swapped them out. Manufacturing defect... I guess?
It may be hard to tell but in the photos the visor is pressed directly against the hook, leaving no room for adjustment.
Old Nov 16, 2023 | 11:01 AM
Can you do some measurements on these? If you provide those, we can share ours.
Perhaps the wrong visors were in the part bin at the factory that day?
Old Nov 17, 2023 | 02:02 AM
Schewe's Avatar
I appreciate it! That could very well be the case.
So measuring on the underside of the visor, I've got about 16 1/2" from the slanted edge to the plastic pull-out.
I also measured the distance of the mount to the hook, which came out to be 11 1/2". Are these similar lengths to yours?
Old Nov 17, 2023 | 12:11 PM
OK. I just got back from taking some pictures. At first I was like "These are the same measurements. Ack!" But then looking more closely where the pivot rod enters the visor on the outside, I saw that more of that rod is exposed on your visor than on mine. Perhaps you only have to push the visor along the rod to the outside?
Here are the pics anyway.
Old Nov 17, 2023 | 04:37 PM
LesMyer's Avatar
Yep, Christine has it figured out. Push the visor over on it's pivot rod.
Old Nov 18, 2023 | 05:19 AM
Schewe's Avatar
Well that turned out to be an embarassingly simple fix. You were definitely right, the visor just needed to be pushed along the pivot rod. I pushed with quite a bit of effort and it wouldn't budge, but pushing while twisting the visor back and forth did the trick. I swear I've tried pushing it before to no avail but I could be wrong. It does beg the question how both ended up in the same state... could just be moving little by little each time they're flipped up and down.
Thanks very much for your help!
Old Nov 18, 2023 | 10:23 AM
As for why you didn't push it back in place until now, I would have been scared to do it unless I knew it was supposed to be pushed back!
Old Nov 18, 2023 | 09:07 PM
AJBert's Avatar
Good eye, Christine!
Old Nov 19, 2023 | 02:50 AM
Originally Posted by Schewe
Well that turned out to be an embarassingly simple fix. ...
This is still better than an expensive fix! LOL
Old Nov 23, 2023 | 04:31 PM
puttster's Avatar
20 years with shaking visors!! Now you're sad, but happy too.
I drove 5 years with the driver side wiper barely touching the glass. This year I bought a new arm from Rockauto for like 10 bucks and in 10 minutes all my problems were solved.
MichaelS
Dec 30, 2021 07:06 PM
Heftynoma
Lifting Tech
22
Mar 4, 2021 08:06 AM
HostileJava
Oct 18, 2016 01:55 PM
konfettix13
Apr 5, 2016 08:15 PM
MoneyBagz
Dec 3, 2012 06:21 PM
