surge,buck,sneeze no code help
Old Jun 30, 2018 | 10:14 AM
marty68's Avatar
marty68 is on a distinguished road
Default surge,buck,sneeze no code help
hello gentlemen.
i am seeking guidance to help steer me in the direction of what is causing my problem....
i have a 2000 4.3 4 dr blazer 270k miles. it has a problem of randomly sneezing, surging , hiccuping. . i have seen no pattern as to when it occurs.
it does it at no throttle mid throttle. it seems as if it is completely shut off, sometimes momentarily illuminating a random dash light. bat,abs, etc. only once has a check engine light occurred. it was p0339 open or short in cam position sensor.....
watching the 02 sensor front it indicates excess fuel just after the sneeze.....
if the sneeze was loss of ignition wouldn't i see a miss count increase?
how is the cam sensor powered? through ignition module?
take a look at screen shot of when the ONLY code was set.
mph 44 ... maybe correct. throttle position 0.0?? i know rpm is wrong. this blazer has never seen 7500 as long as i have owned.
please throw an opinion out.
if you have no clue just tell me ls swap it
Attached Thumbnails surge,buck,sneeze no code help-p0339-1.jpg   surge,buck,sneeze no code help-p0339-2.jpg   surge,buck,sneeze no code help-p0339-3.jpg   surge,buck,sneeze no code help-p0339-4.jpg
Old Jun 30, 2018 | 12:13 PM
GeorgeLG's Avatar
The misfire detection function senses a brief rotation speed change near that cylinders firing point, regardless of cause and not specific to ignition. If all cylinders lose ignition simultaneously or if the the ECM loses power during the glitch, there may not be a detected “misfire”.
George
Old Jul 1, 2018 | 09:22 AM
marty68's Avatar
George
so do you think i am loosing all ignition? and how? is there a pid i can monitor that could help me identify.. not excited about paying $80/hr for someone to look at it and not find it because it is intermittent.
Old Jul 1, 2018 | 10:51 AM
GeorgeLG's Avatar
The camshaft position sensor gets its power on the pink wire via the Eng 1 fuse. The crankshaft position sensor gets its power on the pink wire via the ECM 1 fuse.
Since you get dashboard disturbances during an event my guess at this point is that a simple intermittent failure of one of these 2 sensors is not your problem although if it is, I am thinking crank sensor. Do you have CMP retard on live data as this would help you decide if the cam sensor is your problem during an event?
Back to my no sensor theory, why don't you get a voltage monitor in your cigarette lighter socket and see what happens to system voltage during a hiccup.
George
Old Jul 1, 2018 | 02:15 PM
marty68's Avatar
i will monitor cmp retard this week. ?voltage monitor?.... do you mean there is a voltmeter that plugs into cig lighter? makes sense never seen one i will google search.
if
Old Jul 1, 2018 | 02:49 PM
GeorgeLG's Avatar
Yes on monitor, such as this:
Amazon Amazon
Its a simple way to do a first order check. Some radar detectors also serve this function.
Intermittent problems can be tough. Monitor system voltage, monitor live scanner data. look at freeze frame data if codes appear, look at pending codes, tape a fuel pressure gauge to the windshield while running. Another level of diagnosis is a complete ODBII scan including all mnfg codes, not just generic codes. That's more expensive if you don't know anyone.
George
Old Jul 1, 2018 | 09:01 PM
marty68's Avatar
I monitored cam retard, TC lock up misfire counters today as the wife drove. Cam retard is a bit o -2.9 -3. Is never wavered.. miss count never changed. The TC lock however was moving from 1 to 8100... I have no idea what those numbers mean.
Old Jul 1, 2018 | 09:38 PM
GeorgeLG's Avatar
If cam retard did not move while the engine stumbled then it's unlikely the cam sensor
no misfire codes so it's probably not random individual cylinders.
Why are you monitoring transmission parameters, are you having a problem there?
maybe Les will jump in and give you a more complete set of gauges to measure since he's the resident expert on your bode reader software
let us know about system voltage.
Also you should check the system reference voltage on the three wire sensors of concern such as Crank position
TPS is always wrong?
George
Old Jul 2, 2018 | 05:55 AM
marty68's Avatar
on my way to work this morning I added a "guage" engine run time... this seems to be a counter counting up in seconds. this number resets almost every time the truck stumbles. I am then assuming the stumble is coming from an interruption of either the I gnition source or the power to the computer. again guessing this would explain the gauges (rpm, mph) dropping out. would also explain the intermittent flash of a dash light. at highway speed converter locked up split second interruption car restarts....
.. does any one know where the ground is for the computer? if I ran a wire from that ground and the fed side of ecm1 fuse I could monitor voltage to see if it is dropping out. it could be ground or positive voltage. or a component on ecm...
blazerhelp01
Mar 9, 2015 07:51 PM
Crazyc775
Mar 18, 2013 11:21 AM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 13, 2009 05:08 PM
rob2129us
Dec 19, 2007 10:03 AM
