Syclone turbo setup complete
Old 04-14-2010, 01:29 PM
Benedict1337's Avatar
thats really cool. I wish I could do that to my truck. I've seen a couple jeeps with 4.0L turbo'd really wanted to do my truck after that...
Old 04-14-2010, 03:08 PM
wilb86's Avatar
wilb86 is an unknown quantity at this point
The engine is running at wastegate pressure, around 8psi. The fuel spider was replaced. The fuel pump has been upgraded to a Walbro 255 with new wiring; this raised the base fuel pressure by about 10psi to assist during open loop fueling. During normal operation the o2 feedback and fuel trims maintain driveability.
Old 04-14-2010, 03:43 PM
sifd4x4's Avatar
sifd4x4 is on a distinguished road
yeah sounds like you got all that covered then. I bet she really rolls. its crazy how much room is in the engine bay after you take out all the parts that really aren't necessary for it to run.
Old 04-25-2010, 02:10 PM
Brian_D's Avatar
Videooooooo!!!
Old 04-25-2010, 09:07 PM
blazerboy001's Avatar
blazerboy001 is on a distinguished road
Video. hahaha
Old 05-04-2010, 08:55 AM
wilb86's Avatar
I've got a real quick cellphone video I can upload later when I get home
Old 05-04-2010, 04:51 PM
wilb86's Avatar
http://www.youtube.com/watch?v=OBEd-TNz2Wg
just some part throttle boosting while merging on the highway--nothing exciting or impressive at this point. there's also a couple shots of logging the ignition advance
Old 05-04-2010, 05:37 PM
wilb86's Avatar
Also, FYI:
I don't have any tuning software for this engine. I suspect there may be none available, because it is such a low production model (OBD II 95 model). These 95 OBD II engines are speed density (MAP sensor only) but can only read up to about 105kPA, or basically atmospheric pressure. So the timing won't continue to retard as manifold pressure increases--it can't see boost. But the Syclone can:
The only Blazer timing map I have access to is this from a 2002 model:
The grams/sec calculation is based on measured airflow and rpm. You can see that timing flattens after about .60 grams/sec--that the equivalent of running this 95 Blazer at 105kPA. So even if I had a MAF car this timing issue would still be there once boost climbs high enough.
Now that I have two benchmark values, I'll say that the timing I've been observing hasn't been particularly aggressive. There appears to be less advance at the 100kPA MAP reading than the Syclone has at this pressure. This is probably because the Blazer is designed for 87 octane. I'd say it's equal or less advance than the 2002 Blazer is doing at higher load levels, and less timing than the Syclone at an equivalent 100kPA.
I'm not worried about the timing being a problem yet as far as reliability goes. The vehicle has gone wide-open-throttle but no wideband has been installed yet, so technically that might have been a little risky. Next mod is going to be a wideband to verify the AFR is ok. The 2002 power enrichment maps show a commanded AFR of 12.2:1 :
We'll see what that ends up being at 8psi with this increased fuel pressure. 12:1 would probably be ok these boost levels, maybe a little richer for an extra cushion. Most completely stock calibrations (on factory turbo cars) will command an AFR between 10.2: - 11:1 . I don't think the Syclone has a commanded AFR table, just a bunch of VE terms that are combined together to determine fueling.
Attached Thumbnails Syclone turbo setup complete-syclone_timing.jpg   Syclone turbo setup complete-blazer_2002_timing.jpg   Syclone turbo setup complete-blazer_pe.jpg
Old 05-26-2010, 01:10 PM
wilb86's Avatar
pegged the speedo the other night. effortlessly.
RetroBlazer
03-20-2012 09:58 PM
travisrussell88
11-24-2010 12:20 PM
Unlimitedsp
01-27-2010 08:17 PM
EuroGoldLS
04-19-2007 06:10 PM
Quick Reply: Syclone turbo setup complete
