Synthetic Oil Question
Hey guys,
I had a couple questions regarding synthetic oil.
First of all, since the rear wheel bearings will be replaced, this is a good time to replace the diffy fluid too. So I was thinking about getting some valvoline full synthetic gear oil. How much gear oil does the diffy hold? 3 quarts? 4 quarts? And will full synthetic make it leak?
I also had a similar question for an oil change. I'll be changing my oil at the same time. I had been running a synthetic blend but I saw a good deal on full synthetic. The deal is valvoline synpower full synthetic oil and a mobil 1 oil filter for $22 after rebate. Will full synthetic oil make leaks happen here too?
I dont think it will, my dad switched to synthetic last year and he hasnt seen any leaks, Im not sure about the differential but Im sure it wont leak. and I think it holds 3 qts but dont quote me on that, its just a guess,lol
No it wont leak if it doesnt now. .. Amend that to say if you do a Seafoam crankcase treatment and it doesnt leak after that then it wont with Synth either.
If it DOES start leaking, then just add about 1/2 treatment of Lucas to swell the seals and gaskets back.
In my experience if the car is a bit older and has higher mileage anything over 75k IMO I would stick with the blend rather than fully switching over, (the oil only not sure about the differential oil) I found that some vehicles tend leak due to stress cracking after switching unless done at a lower mileage or when you get your first oil change when the car is new.
The synthetic blend is only at max 30% synthetic and thats at its max depending on what brand you use, some are only 5% synthetic so keep that in mind.
as I said IMO I would stick with the synthetic blend for your motor oil depending on the mileage and condition.
Synthetics causing leaks is a myth, if anything they'll clean sludge and cause an already failed gasket to leak.
Also if you read bobistheoilguy.com there's some great info there. He explains the difference between dino/synthetic (other than the obvious) is that a 10W-30 dino oil is based on a 10 weight base, whereas a synthetic 10W-30 is based on a 30 weight. That's just one of the major differences......
And that ...ahem... is a load of crap. IMO
Mike 98 got it right
Nothing personal... but ONE guy's experience doesnt matter to a hill of beans.. even if it does, I switched my last Tbird to Mobil1 from pennzoil {though religiously serviced .. whew!}..when I bought it at 143,000 miles.. drove it another 150k or so and only time it leaked was when I had a bad oil filter seal.
So I guess MY experience trumps yours... except I've used M1 in about 5 different high mileage cars over a period of 20 years. Without any seepage leaks.
I guess I could be less blunt about it but there was a raging debate on this for a couple weeks on the old Mustang newsgroup and it turned out that a couple guys had bad old style cork gaskets and all the others just heard it from their dad.. or uncle or a guy who knew a guy who was an engineer.
Thanks for the help! I'm going to get my full synthetic oil and filter either later today or tomorrow and change it.
I had 1 more question. Do you know how much gear oil the rear diffy takes? 3 quarts maybe? I was trying to see how much gear oil I needed to change out the fluid in the rear. And also, what about the transfer case? auto tranny fluid for that? How much?
Edit: I used Royal Purple Oil for the rear-end if it means anything
Canam
08-15-2011 06:13 PM
PostRelease
10-27-2010 12:00 PM
