tbi to carb swap
Old Apr 10, 2010 | 11:27 PM
afcr125's Avatar
afcr125 is on a distinguished road
Default tbi to carb swap
i am new to the site first of all, im 18 year old and bought a 1999 s10 zr2 blazer about a year ago. Ive rebuilt the engine from the block up due to a cracked block and a cracked head. I have found that the truck keeps throughing a random multiple misfire code. I have just got a used spider injector set up, becaue the new ones cost too much. If this doesnt work i think id much rather have a carb sitting on that motor than all this tbi crap. What all would i have to change in order to convert over to a carb set up. What parts would i need in order to still be able to pass inspections but have the carb set up. i am trying to do this for pretty cheap.
Old Apr 11, 2010 | 11:00 AM
abig84's Avatar
Don't think you can if you have inspections. You basically bypass the computer and if your inspections require you to not have a check engine light on you'll have a problem. But other then that a intake HEI distrbutor and carb. Also don't know if youR trans might need the computer info to shift right
Old Apr 11, 2010 | 09:38 PM
MTopper's Avatar
Btw, welcome to the blazer forum. place any questions you have in the correct areas so that they can be found easier
Old Apr 12, 2010 | 02:16 AM
foxxie's Avatar
Welcome from New Zealand.
Old Apr 12, 2010 | 02:52 AM
wlorton's Avatar
Welcome!!
Old Apr 13, 2010 | 07:40 AM
Sisk's Avatar
Welcome to the forum from Canada!
Please review the forum rules and all board descriptions. This board is specifically for introductions and not tech related questions. if you have a question please search first, then post it in the appropriate tech board. Thanks.
Old Apr 13, 2010 | 11:06 PM
old skool luvr's Avatar
welcome to the show.
be sure to start a build thread on your ZR, as i'm sure you took lots of pic's when rebuilding that engine.
Old Apr 14, 2010 | 06:30 AM
rriddle3's Avatar
*Moved to '2nd Gen Tech'*
RnB1987
Mar 8, 2015 03:34 PM
Brandon Smith
Dec 22, 2013 12:33 PM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
dcayers
Apr 12, 2009 01:51 PM
BlazerMan85
Mar 7, 2007 12:21 AM
