Tearing down the Sec. Air pump
Old Jan 14, 2007 | 12:18 AM
flyinbrad's Avatar
flyinbrad is an unknown quantity at this point
Default Tearing down the Sec. Air pump
From another post I discovered my aecondary air injectionpump was full of water and has locked up. I called around town and the cheapest pump is $150. I figured this one was already broken so I could not hurt it any more by tearing it down and trying to clean up the corrosion. Has anyone done this and might have some do's or don'ts? '01 4.3L
Old Jan 14, 2007 | 12:23 AM
Default RE: Tearing down the Sec. Air pump
Not that I can remember here. Sorry. But please do take plenty of pictures if you can while you are disassembling it!
Old Jan 14, 2007 | 12:34 AM
flyinbrad's Avatar
Going to take on the task on Tues. I will try to get some good pics.
Old Jan 14, 2007 | 12:39 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
AHAAAA.....so it WAS the water-in-the-pump problem! I knew it with that code you gave me. Just didn't blow the fuse yet hey? Make sure you run a new longer inlet hose up to the area around the battery/overflow tank to keep it from sucking water in again.
Old Jan 14, 2007 | 03:01 AM
20Blazer00's Avatar
ORIGINAL: flyinbrad
Here is a link that could help you if you read it...:
http://www.s-10crewcab.com/phpBB2/vi...light=air+pump
Microman
Jan 19, 2015 03:03 PM
CraigSnedeker
Apr 14, 2010 09:59 AM
chopsling
Jun 4, 2008 02:44 PM
96Ls4Dr
Dec 28, 2007 03:40 PM
96Ls4Dr
Dec 14, 2007 07:17 AM
