Temp Gauge always reading
The unit from Harbor Freight is a Hand Held Amp Meter with the leads and fuse permanently attached to unit itself. You simply plug ( units self attached Fuse) into your Fuse location and whollay the unit reads the Current through the Fuse contacts.
I know it said it reads up to and possibly beyond 20 amps.
I have not used it yet, but looked at it rather closely.
Very inexpensive.
Very inexpensive.
Buttrock21: were you able to determine which circuit has the problem?
The Harbor Freight amp meter looks like a nice tool to have but necessary to find the circuit that is supplying current to the temp & fuel gauges when it should not be. I do not think the dome light circuit should be tied to the gauges circuit.... must have some damaged wires touching somewhere or perhaps the ignition switch.... do not know what passes through it.
I haven't yet been super busy with the holiday season. I hope can check it out tomorrow morning. I haven't had any battery issues even with the vehicle sitting for 3 days and then starting in single digit temperatures. It's not likely to leave me stranded but it's just one of those things that bugs me and I want to know why. I'll definitely post my results. Thank you guys for all your input!
das96blazer
18
03-09-2011 05:21 PM
zakm0n
01-09-2011 07:31 PM
bertrenolds
12-19-2008 07:45 PM
