Temp Gauge always reading
Old Dec 22, 2014 | 12:10 AM
Buttrock21's Avatar
Buttrock21 is on a distinguished road
So is it a multimeter or something similar? Or is it more specific to connect to the small contacts on top of each fuse more easily? And I guess you will be checking if current is flowing when it should not be?
Old Dec 22, 2014 | 09:00 AM
cferry7's Avatar
cferry7 is on a distinguished road
Default Amp meter
The unit from Harbor Freight is a Hand Held Amp Meter with the leads and fuse permanently attached to unit itself. You simply plug ( units self attached Fuse) into your Fuse location and whollay the unit reads the Current through the Fuse contacts.
I know it said it reads up to and possibly beyond 20 amps.
I have not used it yet, but looked at it rather closely.
Very inexpensive.
Old Dec 28, 2014 | 03:21 AM
cferry7's Avatar
Cool
This tool been speaking of :
Mfg. CENTECH item # 67725
I have purchased and it does work as
Described.
20 amp upper limit, per
Manufacturer.
Tested reading 7 amps
In one Fuse location.
Old Dec 28, 2014 | 09:46 AM
LannyL81's Avatar
Buttrock21: were you able to determine which circuit has the problem?
The Harbor Freight amp meter looks like a nice tool to have but necessary to find the circuit that is supplying current to the temp & fuel gauges when it should not be. I do not think the dome light circuit should be tied to the gauges circuit.... must have some damaged wires touching somewhere or perhaps the ignition switch.... do not know what passes through it.
Old Jan 4, 2015 | 02:00 AM
Buttrock21's Avatar
I haven't yet been super busy with the holiday season. I hope can check it out tomorrow morning. I haven't had any battery issues even with the vehicle sitting for 3 days and then starting in single digit temperatures. It's not likely to leave me stranded but it's just one of those things that bugs me and I want to know why. I'll definitely post my results. Thank you guys for all your input!
morganpainter
May 1, 2013 12:25 PM
das96blazer
18
Mar 9, 2011 05:21 PM
zakm0n
Jan 9, 2011 07:31 PM
bertrenolds
Dec 19, 2008 07:45 PM
ant2297
Sep 28, 2008 07:40 PM
