Temp Gauge isn't working
Old Jul 21, 2018 | 08:44 PM
Ryan Steele's Avatar
Ryan Steele is on a distinguished road
Default Temp Gauge isn't working
My temp Gauge isn't working on my 2003 blazer 4.3 vortec. I replaced the coolant temp sensor and still nothing. After a few minutes of it sitting it will work for about 15 to 20 seconds then drop back down. I'm lost in what it would be.
Old Jul 22, 2018 | 02:13 AM
Mike.308's Avatar
Hook up with dongle. Compare coolant temperature reading to the dash gauge.
Old Jul 23, 2018 | 11:14 AM
LesMyer's Avatar
As Mike says - hook up a scanner and read the temp the PCM is seeing. Bet the stepper motor in the instrument cluster is bad!! If the PCM sees correct temp and rest of the gauges work - then the gauge cluster is absolutely the problem. Data for all gauges comes from the PCM into the instrument cluster on a single data line (which is interpreted internally in the gauge cluster), so the problem would have to be internal.
telecaster
Dec 18, 2016 02:58 PM
boscoedoodle
Nov 24, 2009 10:56 PM
bartonmd
Nov 29, 2008 08:02 AM
