Temp issues...
Old Apr 22, 2007 | 04:57 PM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
Default Temp issues...
I've used the search but coudln't find an answer so i figured i'd post my own. So lately my blazer's temp has been a little weird. It has been heating up to the proper temp right below 210 and then cooling off, but it seems like the t-stat was staying open after that because it would never heat up again. I figured since it was a fail-safe one that it was just getting stuck open.
So i went and bought a new 195 degree t-stat and i put it in. Now it just heats up to the quarter mark and thats all it does. It won't heat up past that at all, and it's fairly warm outside now around 70-80. So do you all think it's the t-stat or something else causing the problem?
Old Apr 22, 2007 | 09:39 PM
fernandoh's Avatar
fernandoh is an unknown quantity at this point
Default RE: Temp issues...
Maybe is only the temp sender (name??) to the gauge starting to fail. Put your hand at the upper hose when the engine is definite hot. You will not support more than a second or two. If is only warm is the thermostat. I just change mine and I observed this. Fuel consumption may rise withthe under designed temp.
swdockter's Avatar
swdockter is an unknown quantity at this point
i'd recommend replacing temp sensor.
Old Apr 22, 2007 | 10:24 PM
mrspeedy69's Avatar
Where is the Temp Sensor at on these? Is it hard to replace?
Old Apr 23, 2007 | 11:25 AM
swdockter's Avatar
on my 93 it was on the passenger side head.
Search resulted in many hits but this pretty much describes it....
https://blazerforum.com/m_22787/tm.htm
Old Apr 24, 2007 | 12:55 AM
mrspeedy69's Avatar
Thanks for the help. I'll look for it, for some reason i was thinking there was a sensor in the actual radiator right below the upper radiator hose that goes to the T-stat.
Old Apr 26, 2007 | 11:28 PM
mrspeedy69's Avatar
Do you guys think it could be anything else besides that?
Old Apr 27, 2007 | 12:00 AM
whiplash_s's Avatar
whiplash_s is an unknown quantity at this point
my 93 S10 blazer is running at 210 temp with a/c on max and driving in city traffic, is that normal operating temp?
seems a bit hot to me. I'm only comparing to my 84 cavalier that runs at 180 with a/c on.
Old Apr 27, 2007 | 01:12 AM
mrspeedy69's Avatar
I actually believe thats about right. Maybe a little cooler but since you have the air on and stuff thats probably about right.
zakm0n
Jan 9, 2011 07:31 PM
mboehler
Jan 16, 2009 07:16 AM
bertrenolds
Dec 19, 2008 07:45 PM
DaddyCop03
May 11, 2008 09:07 PM
naf821
Aug 8, 2007 07:19 AM
