Temp problem
Old Nov 25, 2007 | 01:44 PM
95Blazer95's Avatar
95Blazer95 is an unknown quantity at this point
Default Temp problem
I have a 95 blazer with a bit of a sputter when accelerating and at idle. The sputter only occurs when the outside temperature is relatively warm. When it is cooler outside, it runs perfect.Could this be a bad intake air temperature sensor?
Old Nov 27, 2007 | 08:56 PM
Hanr3's Avatar
Default RE: Temp problem
It could be, or your a/c is cylceing on and off. It will cylce in teh winter too, depends on your HVAC setting. A/C is used to keep the fog off the windows. Heat and snow make mositure, and heat alone wont prevent your windows from fogging over, the a/c pulls the moisture from the air.
Next time it happens, turn off your HVAC system and see if it goes away?
If not, your TPS may be on its way out. Get it tested.
zakm0n
Jan 9, 2011 07:31 PM
mboehler
Jan 16, 2009 07:16 AM
bertrenolds
Dec 19, 2008 07:45 PM
DaddyCop03
May 11, 2008 09:07 PM
naf821
Aug 8, 2007 07:19 AM
