Temperature Control Selection Switch PROBLEM??
It would also be interesting to find out if the old controls have fluid in them, because there is a TSB on the HVAC controls malfunctioning when the vacuum switch on the transfer case fails allowing fluids to be sucked into the vacuum side of the controls...GM has a newer switch with a stronger seal to fix this problem.
I have a 95 s10 and the temperature control switch, actually a potentiometer is broken. Any idea on where to get one of these instead of the whole panel?
If someone can measurethe resistance of one of these this would work.
Having the same issue with 95 blazer. heat on floor and dash. vacuum lines all good. next step, replace heat selector switch. anybody know how to get the control panel out of the dash? (next to the radio) appreciate any help
BigMarcus
Oct 29, 2007 09:26 AM
