Temperature rises while standing
Hello,
i have a 2nd gen trailblazer 2001 4.3 V6.
today the check gauges light went on. I realized that the engine temperature was very high. Whenever I stopped it went up again, when i drove it went back to normal. I checked cooler fluid level and saw that it was kinda low. I refilled but the temp still rises while im standing. When i shift on p while standing and increase the rpm the temp also goes down immediately. I checked the ventilator and its still turning.
Also since I own this car the heater does not work. It blows out, but only cold air.
anyone of you guys has an idea what could be wrong with the car?
thanks in advance!
thanks in advance!
This may work, I`ve done it. Buy some hose that fit the heater core fittings (2 different sizes) reverse the flow using a garden hose on the outlet and make sure the inlet hose is long enough to reach over the side of your truck. Slowly increase pressure and reverse flush the core. It works
This may work, I`ve done it. Buy some hose that fit the heater core fittings (2 different sizes) reverse the flow using a garden hose on the outlet and make sure the inlet hose is long enough to reach over the side of your truck. Slowly increase pressure and reverse flush the core. It works https://www.youtube.com/watch?v=dcL_0TWeZJY
I would definitely try flushing the heater core. what I did was use a funnel connected to the hose and poured a small bottle of CLR in. Waited 10 minutes and flushed it both directions until it ran clear. The stuff that came out was black. I have had good heat ever since.
SimonV
10-18-2014 03:26 PM
monette999
02-01-2011 08:23 AM
pmezo
28
11-06-2010 04:30 PM
