Testing of 2001 NP8 Transfer Case Encoder Motor and Motor Lock
http://forums.trailvoy.com/showthread.php?t=90437
oops - looks like codes for trailblazer are different from the ones in your post. So probably need to dig some more for the correct addresses to query on my Blazer - but it still may be possible if I can find them on line or figure them out myself.
Les
The DTC's are there, C, B, & U codes, you just have to cross it over from hieroglyphics. The scan program he's using looks a real PITA. It doesn't have to be that difficult: Connect to the network, access the module you want, retrieve the DTC's, and diagnose it
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
Hi Les , Have you tried C6 FE F1 19 FF FF 00 in the terminal , this should give you a list of all possible code ( not current trouble ) that every module could ever have .....If this works look for the module between the addresses $18-$1F...the one in this bracket should be the TCCM for your truck because you now know that 1A is not the address of the TCCM. If you find it then run 6C ?? F1 19 C2 FF 00 and it should tell you the code as per the info in the link you posted. ( ?? being your TCCM address)
In the received data the 3rd byte is the address of the different modules and if you download a hexidecimal chart off of the net you can see all the address between 18 and 1F....
Having played with my friends 2000 blazer today with NP8 , I'm 99% sure that your TCCM IS at $1A and if you use the code 6C 1A F1 19 C2 FF 00
you will get your DTC just like your post read up ......and 6C 1A F1 14 will clear your code when your ready..... 2000-02 and 03 are all at $1A ....I'll bet most GM's are
Let us know if this helped you.
Seems I always have to do things the hard way! :-)
Hi Captain , on the NV233 case , can one still use a scan tool tool ? or only the jumper method ?
On the NV233, the TCCM is linked to the PCM, but it does not use classII serial data communication. It needs to request & receive wheel speed data from the PCM before it will command a range shift, (in and out of LOW range). It also "tells" the PCM when and if the front axle is engaged. Codes are retrieved only by jumping the pins.
Thanks for the info , I was wondering why I don't see an address when I query for one.
No address, no porch light, nobody home
On your own for diagnosing.
LOL , thanks ...I don't have any problems to diagnose just like learning , a friend dropped by today with his 2000 blazer and I verified that I could read codes if there was any on his TCCM , he has the NP8 option , I have the NP1 and cant read via scanner.....just love learning.
