Thermostats
Old Aug 26, 2009 | 01:57 PM
xCHIPx's Avatar
xCHIPx is on a distinguished road
Default Thermostats
I have a 99 blazer and was wondering if I could run a 160 on my truck or do I have to have a 180?
Old Aug 26, 2009 | 02:31 PM
rriddle3's Avatar
Neither. Use a 195 degree thermostat unless you want your engine to stay in open loop operation and let your gas mileage and power suffer.
Old Aug 27, 2009 | 12:32 AM
xCHIPx's Avatar
So run a higher one?
Would it make my motor run hoter?
Old Aug 27, 2009 | 02:47 AM
4x4blazerguy's Avatar
Engines that are computer controlled require higher heat to operate correctly. 195 degree thermostats are normal. Anything colder will do as explained above. Gas mileage & overall performance will be affected for the worse.
These engines need to run hot (210-220 degrees.) That is one reason anti freeze is important to use instead of water as in the old days. Because a 50-50 mixture of anti freeze & water raises the boiling point several degrees above 212 degrees of plain water.
