third brake light comes on but the other two dont work.
Old Sep 14, 2009 | 09:17 PM
Self's Avatar
Self is on a distinguished road
Question third brake light comes on but the other two dont work.
hello. I have a 1998 chevy blazer ls 2door 4x4. I have the third brake light. but the two other brake lights and the brake lights for the trailer does not work. i have turn signals tail lights and reverse lights. all the bulbs are new. i replaced the brake switch. i have power coming from the brake switch out. I have re wired the trailer wiring. i have been trying to figure this out for 3 days and i am at the point of fustration. can some one please help me.
Old Sep 14, 2009 | 10:23 PM
2doorblazer's Avatar
2doorblazer is on a distinguished road
i had the same prob an it was my hazard switch an i had all the other light just not the 2 lower ones mine is a 98 2 door 2wheel
Old Sep 14, 2009 | 11:37 PM
AJBert's Avatar
Hazard switch, there is/was a recall on it. Bring it down to your local dealer and the should change it out free of charge.
Old Sep 15, 2009 | 07:31 AM
recall wish thay would of told me about it when i got mine form the dealer but it was under 20 bucks an about half an hour work to put the new one in
Old Sep 16, 2009 | 10:09 AM
Self's Avatar
Unhappy
I STILL HAVE THE ISSUE AND I REPLKACED THE HAZZARD SWITCH
Old Sep 16, 2009 | 11:07 AM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
did you check the underhood fuses?
Old Sep 16, 2009 | 02:31 PM
Self's Avatar
all the fuses are good. is there a relay switch i may be over looking? i have been trying to trace the ground wire. but do not know where to locate it.
Old Sep 16, 2009 | 02:32 PM
Self's Avatar
i have tested the fuse and i do have power going to it as well from the brake light switch but none to the brake lights
Old Sep 17, 2009 | 12:46 AM
if you checked all the fuses theres one fuse in the dash and one for each light under the hood i would start checking the grounds i think they all ground on the frame behind the bumper
Old Sep 19, 2009 | 02:29 AM
95POSmoneypit's Avatar
95POSmoneypit is on a distinguished road
Just a thought, I had a issue similar and it turned out to be my trailer lights had rubbed against the frame and grounded out. Not sure why the center would work though... Good luck!
