Three Button 4WD Question
Old Jul 19, 2014 | 06:42 PM
LannyL81's Avatar
Default Three Button 4WD Question
Can someone tell me how the vacuum line between the actuator under the battery tray and the T-case is routed on the three button 4WD Blazers?
Old Jul 19, 2014 | 07:29 PM
It leaves the vacuum switch and goes up and over the transfer case, (usually taped together with the vent and source lines). Then it goes up behind the right cylinder head, and forward along the right side of the intake manifold. At the rear of the alternator it heads down toward the actuator. It is inside a black plastic split loom from the rear of the engine to the actuator.
Old Jul 20, 2014 | 11:40 AM
LannyL81's Avatar
Thank you Captain.
Old Jul 20, 2014 | 11:59 AM
mk123's Avatar
mk123 is on a distinguished road
Captain, if a person doesn't have much experience working on cars is this something that is easy enough for them to tackle? Thanks!
Old Jul 20, 2014 | 07:56 PM
There are 3 vacuum lines at the switch on the transfer case. Each line is attached to a specific port on the switch. One is the vacuum source from the engine. It should have manifold vacuum at all times. The second line Tee's in with the vent on top of the transfer case, and from there it is routed to the top of the transmission dipstick tube, with a filter at the end. This is the vent line for the transfer case and the vacuum actuator. The third line goes to the vacuum actuator to engage the right front axle when 4WD is selected. If you replace the lines one at a time, it's tough to screw 'em up Skill level, on a 1 to 10 scale, (1 being the easiest) it's probably a 2.
762mm
17
Nov 21, 2024 11:36 AM
Flyfishen
Jun 18, 2019 11:22 AM
litterbox99
Dec 28, 2014 05:49 AM
NVANZEE
Mar 20, 2009 05:43 PM
Rvega
Mar 4, 2009 05:35 PM
