Thud when stopping
Old Aug 17, 2012 | 11:42 AM
Tim_1963's Avatar
Tim_1963 is on a distinguished road
Default Thud when stopping
I am getting a loud "thud" or "thunk" after stopping at low speed. It comes form the rear/center of the truck. Is this a U- or CV- joint issue. Anyone fix the problem themselves. 2000 Blazer LS 4WD 163,000 miles
Thx.
Old Aug 17, 2012 | 11:46 AM
chris015's Avatar
id look at the u joints,and maybe the front hubs.
Old Aug 17, 2012 | 12:22 PM
50lb_cat's Avatar
+1, check for play in the u joints, hubs and ball joints. U joints are easy, the only problem is if they are stock then they have an internal nylon "clip" that you have to melt out. The new ones have a metal, external clip.
Old Aug 17, 2012 | 02:34 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Check pads/rotors?
Old Aug 17, 2012 | 04:44 PM
step66's Avatar
Rear/center of the unit? U-joints...Any unit over 80-100K should have them replaced any way! Easy job!
Old Aug 18, 2012 | 10:52 AM
bromanjr's Avatar
bromanjr is on a distinguished road
Thx.
You should check your Torsion bar mounts, at the rear of the bars there is a cross-member that goes across and is attached with a mount/hanger on each end. I hear they can be a pain to change but can cause that noise.
Old Aug 18, 2012 | 11:54 AM
chris015's Avatar
Originally Posted by bromanjr
You should check you Torsion bar mounts, at the rear of the bars there is a cross-member that goes across and is attached with a mount/hanger on each end. I hear they can be a pain to change but can cause that noise.
Its not that. trust me, i drove around for 6 months with both of mine broke. only thing they ever did was clunk while turning.
Old Aug 19, 2012 | 03:20 PM
abig84's Avatar
its its like a thump it might just be the actual axle itself shifting. my 90 fullsize does this usually when you left off the brakes the its kinda springs back to normal position. hard to explain but its kinda normal for a old worn out truck like mine
camino88
Feb 5, 2010 09:47 PM
steve8650
Feb 5, 2010 05:42 AM
vrryder
Feb 2, 2010 12:51 PM
laboone
Sep 24, 2007 04:22 PM
fenderfree
Dec 14, 2005 09:04 PM
