Thud
Old Sep 21, 2007 | 03:22 PM
laboone's Avatar
laboone is an unknown quantity at this point
Default Thud
I've been through the old posts and have yet to find an answer to my dilema. I'm getting a loud thud when I hit a bump. Definatly worse on the passenger side. I have replaced the lower ball joints, shocks, and adjusted the Z trim(ride height). Looks more aggresive but it hasn't resolved the problem. The other suspension parts appear to be in pretty good shape. This is driving me insane. Please send other suggestions.
Old Sep 21, 2007 | 05:30 PM
rriddle3's Avatar
Default RE: Thud
Is the noise coming from only the front end and does it happen as you hit a bump or as you come off the bump?
Old Sep 24, 2007 | 01:00 PM
laboone's Avatar
Default RE: Thud
More like when I hit the bump. Almost appears to be when the suspension has risen to its highest point. Noise is only in the front end and sounds like metal hitting. There are no signs of metal on metal strikes or rubbing. I checked to make sure the battery was sucure and not bouncing around and it is definatley secure. It has baffled me so far.
Old Sep 24, 2007 | 04:22 PM
ksibley603's Avatar
ksibley603 is an unknown quantity at this point
Default RE: Thud
Search for hood hinge, I had the same noise and thought it was the front end till I read the post. I folded a rag and put it at the passenger side hood hinge and it solved the problem. If I remember there is a washer that can be replaced
Blade_24k
Jul 23, 2012 08:22 PM
camino88
Feb 5, 2010 09:47 PM
steve8650
Feb 5, 2010 05:42 AM
vrryder
Feb 2, 2010 12:51 PM
fenderfree
Dec 14, 2005 09:04 PM
