ticking noise on 2000 blazer, just before the trans pan
Old Apr 14, 2011 | 10:48 AM
outsydthbox's Avatar
outsydthbox is on a distinguished road
Originally Posted by marlboro124
ya i can hear it but barely when its in park, so whats the next thing i should do or have the shop do? exactly what is it & any idea how much it would run roughly?
I had a similar sound, quite a few years ago. I put up with it for several months until it got really annoying. By that time, it was real obvious...the " "engine to transmission" bolts had come loose, so their was a "gap" between them! This allowed flex, which in turn, cracked the flex plate, right up next to the crankshaft bolts.
Old Apr 20, 2011 | 04:04 AM
marlboro124's Avatar
marlboro124 is on a distinguished road
i just found out that my flex plate is fine no cracks nothing, so what else could it be? anyone else know?
well when it started doing it, i only drove it for the next few days and i got tired of it already and took it to the shop and its almost been a week from tomorrow, i just called the guy earlier and he said he still figuring it out cuz ppl were already ahead of me so hopefully i find out tomorrow, TOutssydthbox - what did they have to do? like drop the trans, did they get it from the circular part from underneath?
Last edited by swartlkk; Apr 20, 2011 at 07:00 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Apr 23, 2011 | 10:35 AM
.......TOutssydthbox - what did they have to do? like drop the trans, did they get it from the circular part from underneath?
Yes, drop the trans & replace flexplate. But if that has been checked & is good, there are a few other things you might check.
As DySfUnCtIoNaL said, noised can be hard to track. It could be an exhaust leak. They do get louder when under load.
Another thing (that also happened to me)...loud ticking noise, that kept getting louder. finally, I hear this loud "BANG"... I had a loose spark plug, ( I'm supposed to torque those?) that eventually got loose enough, that it blew out of the hole, & hit the inner fender. It was still hanging from the plug wire.
Good luck
Old Apr 24, 2011 | 11:42 AM
Well see the reason why I'm asking all these questions is because I'm also paying off this stupid thing its 500 to do the work and I'm thinking of getting rid of it I don't have 500 I could use that for a couple payments, that's why I having done anything yet Idk what to do from here
Old Apr 24, 2011 | 12:45 PM
I feel your pain. That's a tough decision to make. Even if you decide to get rid of it, it will be worth more (at time of sale) if their aren't any strange noises. I hope, for your sake, it's something simple & easy (inexpensive).....wait...you said...."its 500 to do the work"...did your mechanic "find the problem?" What did they say is wrong?
It might be good to get a "second opinion"...from a different shop.
Old Apr 25, 2011 | 12:15 PM
well he said he found where its coming from but not exactly what the problem is thats making all the racket. the only way he can tell if the flex plate is broke is if i allowed him to drop the trans and see, but at second thought, what if the plate is fine, no damages, cracks, dents, or even broke thats like throwing my money away and i had my trans dropped for nothing.
Old Apr 25, 2011 | 08:05 PM
I tend to agree with you...Unless the "trans-to engine" bolts have backed out, allowing flex, between the engine & tranny, I don't see how it could crack. As I remember, the "ticking" (from a cracked flex plate)has more of a "metallic" sound to it.
Have you had any major exhaust work done? Like, a header? Instead of taking it to another mechanic, have you thought about a muffler/exhaust shop? A quick inspection could, at least, remove that as a possible cause.
Old Apr 25, 2011 | 08:18 PM
kevlar974's Avatar
kevlar974 is on a distinguished road
I would try pulling the starter first to see if the gear is throwing out and retracting properly. Its and easier check and a cheaper fix. Good Luck.
Old May 6, 2011 | 02:29 PM
ive actually thought about what u said, especially in reverse it sounds like something is rolling inside but i could be wrong.
Old Oct 6, 2011 | 11:51 AM
Well, I figured out the problem, like RIFLEMAN 308 said, it was the gear inside of the starter. The spring inside failed by holding the gear back and that was constantly hitting the flexplate. Sorry been so long Ive been on here, I forgot about this whole site then when I remembered Posting my problem, I forgot my user & pass at the same time. But I wanted to say thank you to everyones advice. Not only that but saved me $500 bucks. Its amazing what a car part can do when it fails lol.
