timing change - set timing?
Old Apr 17, 2010 | 06:18 PM
hotrodln's Avatar
hotrodln is on a distinguished road
Default timing change - set timing?
Ok I replaced the timing chain set on my 95 today. I probably ought to check the ignition timing? or is this one of those that sets itself? If i need to do it with a timing light, is there a wire i should disconnect first? Thanks !!
Old Apr 17, 2010 | 10:38 PM
abig84's Avatar
not 100% about s10s. but i recently picked up a 90 fullsize with a tbi and theres a sticker under the hood that tells you in detail exactly how to check the timing and which wire to disconnect and where to find it
Old Apr 18, 2010 | 08:00 AM
hotrodln's Avatar
when in doubt, check the sticker! good advice that i always forget !!
Old Apr 25, 2010 | 02:51 PM
hotrodln's Avatar
OK i checked the sticker " says to disconnect the timing plug".....but it doesn't show any diagram of where that is.........there are two connections to the distributor??is it one of those? ANy help is appreciated. Thanks pat
Old Apr 25, 2010 | 04:21 PM
If this is the older setup with adjustable timing, the timing connector is located off the passenger side of the transmission tunnel under the front edge of the carpet inside the truck.
Old Apr 25, 2010 | 05:06 PM
hotrodln's Avatar
so should i look up under the dash? pull the carpet back on the passenger side? anybody got a picture of it? the eng runs great right now, but i just pulled the distributor and put it back based on my paint marks.....pat
Old Apr 25, 2010 | 07:32 PM
hotrodln's Avatar
do you think the timing connector is labled? i've got the factory repair manual, but when i look up changing the timing it says to llook in another book.......something like the emmissions and driveablilty manual or something like that.........
Old Apr 25, 2010 | 08:17 PM
Not likely. Just have a look. It's all by itself.
Old Apr 25, 2010 | 09:46 PM
hotrodln's Avatar
ok i'll check it out tomorrow........thanks!
Old Apr 26, 2010 | 12:18 PM
hotrodln's Avatar
well i pulled the carpet back about 6 inches and didn't see any connectors.....maybe they moved it to a better spot? there's two plugs into the back of the distributor..........not one of those? i wish i had that "other" factory manual!!
