Too rich Codes
1996 GMC Jimmy, 4.3 DUH! DTC codes p0172 and p0175 pop up. Truck runs great, starts great and i cant even tell there is an issue but my computer says there is. Regaurdless i need to figure out the issue. MAF and MAP readouts seem good. I would like some ranges of what my sensors "should" be saying so i can narrow down what is causing my issue. I did notice my fuel trim is at about -13.xx on both banks (ST FTRM) at operateing temp. If i'm corect that means it's trying to lean it out like crazy right? This is at idle.
Can someone hook a reader to their truck and tell me what all the sensors read at operating temp.
Last edited by rriddle3; Jul 16, 2011 at 05:00 PM. Reason: COMBINING CONSECUTIVE POSTS
the MAF sensor seemed clean, i cleaned it with brake parts cleaner anyway. The MAP reading looked normal when i viewed it with my scan tool but i didnt check the vacuum line for it, where is it?
You cleaned the maf with brake cleaner? You may have damaged it. You should only clean a maf with electrical parts cleaner. I need to check out how rhe map is set up. If it is attached to the manifold then it may not have a vac line.
strawhatmatt
22
May 20, 2013 12:02 AM
Swaggner
Oct 11, 2011 11:33 AM
lekahj
Apr 20, 2011 03:01 PM
Chastity
13
Jan 10, 2011 07:22 PM
uncledenny
Jan 8, 2010 04:09 PM
