tranny issues...grrrrrrr
was merging onto the interstate and heard the dreaded sound that sounds like a turbo winding up except it was coming from my transmission. will not shift out of low gear and i have no reverse...wtf
Quote: AllDataDIY.com
A/T - 4L60/65E No Reverse/2nd or 4th Gear
Bulletin No.: 00-07-30-022C
Date: December 10, 2004
TECHNICAL
Subject:
No Reverse, Second Gear or Fourth Gear (Replace Reaction Sun Shell with More Robust Heat Treated Parts)
Models:
1993-2005 Cars and Light Duty Trucks
with 4L60/65-E Automatic Transmission (RPOs M30 or M32)
Supercede:
This bulletin is being revised to correct two part numbers referenced in the vehicle groups and add text after the Parts Information table. Please discard Corporate Bulletin Number 00-07-30-022B (Section 07 - Transmission/Transaxle).
Condition
Some customers may comment on a no reverse, no second or no fourth gear condition. First and third gears will operate properly.
Cause
The reaction sun gear (673) may not hold inside the reaction sun shell (670).
Correction
Important: There are FOUR distinct groups of vehicles and repair procedures involved.
^ Vehicles built in the 2001 model year and prior that make use of a reaction shaft to shell thrust washer:
^ The sun shell can be identified by four square holes used to retain the thrust washer. Use reaction sun shell P/N 24228345 reaction carrier to shell thrust washer (699B) P/N 8642202 and reaction sun gear shell thrust washer (674) P/N 8642331 along with the appropriate seals and washers listed below.
^ Vehicles built in the 2001 model year and prior that have had previous service to the reaction sun shell:
^ It is possible that some 2001 and prior model year vehicles have had previous service to the reaction sun shell. At the time of service, these vehicles may have been updated with a Reaction Sun Shell Kit (Refer to Service Bulletin 02-07-30-003) without four square holes to retain the thrust washer. If it is found in a 2001 model year and prior vehicles that the reaction sun shell DOES NOT have four square holes to retain the thrust washer, these vehicles must be serviced with P/Ns 24229825 (674), 24217328 and 8642331 along with the appropriate seals and washers listed below.
^ Vehicles built in the 2001 model year and later that make use of a reaction shaft to shell thrust bearing:
^ The sun shell can be identified by no holes to retain the thrust washer. Use reaction sun shell, P/N 24229825, reaction carrier shaft to shell thrust bearing (669A), P/N 24217328 and reaction sun gear shell thrust washer (674), P/N 8642331 along with the appropriate seals and washers listed below.
^ Vehicles built from November, 2001 through June, 2002:
^ These vehicles should have the reaction carrier shaft replaced when the sun shell is replaced. Use shell kit P/N 24229853, which contains a sun shell (670), a reaction carrier shaft (666), a reaction carrier shaft to shell thrust bearing (669A) and a reaction sun gear shell thrust washer (674). The appropriate seals and washers listed below should also be used.
^ When servicing the transmission as a result of this condition the transmission oil cooler and lines MUST be flushed. Refer to Corporate Bulletin Number 02-07-30-052.
Follow the service procedure below for diagnosis and correction of the no reverse, no second, no forth condition.
Important: If metallic debris is found on the transmission magnet, the transmission must be completely disassembled and cleaned. Metallic debris is defined as broken parts and pieces of internal transmission components. This should not be confused with typical "normal" fine particles found on all transmission magnets. Failure to properly clean the transmission case and internal components may lead to additional repeat repairs.
TECHNICAL
Subject:
Models:
Supercede:
Condition
Cause
Correction
I HAVE AN EXTENDEND WARRENTY $100 DEDUCTIBLE GO ME
Definitely. Get it into the dealership. If you have AAA, have them come get it with a flatbed and take it to the dealership for you.
will hopefully be able to get it in some time tomorrow but don't know when...i'm a Fex Ex driver and it's an awfully busy time of year. the good thing is i drive a work truck every day so i don't care when i get my blazer back
FED EX sorry i'm tired
Make sure you don't drive it in this condition. Have the dealer or AAA tow it or they may now honor your deductible..
Flatbed or tow by the rear end.
Turn in the tow bill to your insurance company, most cover tow bills and will subtract it from your next months payment.
ski.dive
02-07-2014 05:18 AM
mmmorris
06-08-2009 11:24 AM
