Transfer case Exploded view
Old 02-24-2010, 06:09 AM
I can't remember seeing one, but there really isn't much to it. Disconnect the electrical connections and unbolt the unit. There should be pictures floating around in various threads.
Old 03-31-2010, 01:14 PM
cyberdog's Avatar
cyberdog is on a distinguished road
Ordered a new Encoder motor and replaced so now i have working 4x4 Just done short testruns.
First thing i noticed is that it sound like the chain is dry so i wont drive anymore with 4x4 until i have checked that out and filled oil.
Second: Sounds almost like the chain isnt under enough tension ?! Does it have a tensioner or ?
Third: When i did sharp turn slow when in 4hi it almost sound like the chain is skipping a few teeth is it maybe called cogging ) ? ANy ideas ?
Old 03-31-2010, 01:24 PM
Where is the sound coming from? Are you turning on a high traction surface (asphalt or concrete)? If so, this is a no-no when locked in 4wd.
Old 03-31-2010, 01:45 PM
cyberdog's Avatar
It was on snow that i had really great tracion on. ALso is there any tensioner for the chain ? If yes is it automatic ( oil ? ) or manual ?..
The sound came from the TC but i am not 100% sure.
Old 03-31-2010, 03:31 PM
There is no tensioner on the chain in the transfer case. It could be that the shift fork for the front output inside the transfer case is not fully engaging onto the drive gear.
If the sound were coming more from the front, it could be a problem with the front axle engagement.
Flyfishen
06-18-2019 11:22 AM
ragainff
01-21-2011 01:02 PM
op952dr
04-03-2009 04:09 PM
goken50
02-13-2006 04:35 PM
Quick Reply: Transfer case Exploded view
