Transfer case Vacuum switch
Old Mar 3, 2009 | 09:10 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
Default Transfer case Vacuum switch
Does someone have a pic or illustration showing the vacuum switch on the transfer case and which line goes where. I know that one is eng. vac, one to atmosphere and one to the front diff. vac. actuator, but specifically which one goes where on the switch. Also what retains the vac. lines on the switch? I know that there is a plastic block that the lines are in at the switch, but what keeps that block from vibating or pulling loose? I thought I had seen an illustration somewhere before but I can't find it. Thanks for your help.
Old Mar 4, 2009 | 07:20 AM
I have never seen a diagram showing which hose goes where on the switch. There should be a connector on the end of the hoses. This connector has a clocking tab which will go onto the switch one way (well, one way easily anyhow).
Here is a pic showing where the switch is:
Then there is this picture, but I do not think it gives enough detail for what hose goes where:
Old Mar 4, 2009 | 08:01 AM
SockJock's Avatar
Thanks. The tcase diagram you posted appears to show what I was looking for. I think someone had just blown up the switch area of that same diagram. It may have been on another forum. Does that connector just push on to the switch or does something retain it?
Also I have done away with my vac. actuator, should I just cap the eng vac line or will that cause a code? I know there is a sensor next to my battery that is hooked to the same line that was attached to my vac actuator. I just capped the actuator line at the T connection and left the sensor vac hooked up.
Old Mar 4, 2009 | 09:18 AM
It just pushes on.
If you have done away with your vacuum actuator, you could do away with the entire vacuum system back on the transfer case. Just plug off the vacuum line at the engine that runs back there. There is no need for it.
Old Mar 4, 2009 | 11:55 AM
SockJock's Avatar
I may do that to eliminate the possibilities of vacuum leak in that area..
cjb2145
18
Oct 6, 2018 04:46 PM
paulp64131
Dec 26, 2011 03:52 AM
rickcact
Sep 28, 2010 04:52 PM
slowhand
Jan 5, 2010 05:14 AM
fred96
Jun 8, 2007 11:23 AM
